anyone running a obd1 in a 0bd0 car w/ VSS
Old Jun 1, 2004 | 04:52 PM
coleon's Avatar
RedNeck Refab.Inc
Default anyone running a obd1 in a 0bd0 car w/ VSS
How did you reprogram your ecu, what ecu are you running? Im running a obd1 P72 on a h22 w/ no v-tec, Did you knull out the vss feed to the obd0 cluster to trick ecu?uberdata?
BLAKE !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !
reprogram p72 to not see vss?????
Old Jun 1, 2004 | 05:13 PM
Josh's Avatar
Dr. Doom
i thought P72 was a GS-R ecu?
Old Jun 1, 2004 | 05:43 PM
coleon's Avatar
RedNeck Refab.Inc
it is, Is there someting that you dont get?I am more than willing
To explain it further if need be, but all in all time will tell, How do you knull the VSS, Internal???? Put a 280ohm resistor between pin 4 and 22 on 28 din single flash eprom chip?
Believe me you I am trying to figure it out and the appropriete resources are helpin as well. Hopefully I diddent offend anyone in the process.. but if I did Im sorry.................
And When It Rains.. It Pours..
Roughneck Refab .Inc
Old Jun 1, 2004 | 05:44 PM
Josh's Avatar
Dr. Doom
i guess i just misunderstood what you said about no vtec, i see what you are saying now, that's why it made no sense to me. sorry.
Old Jun 1, 2004 | 05:46 PM
MacGruber's Avatar
MaDe Of MoNeY
what kind of car? if its a ef just get a jdm gauge cluster and a vss and hook it up.
Originally Posted by Z28ricer
"What shitty poorly fitted aero did you ziptie on today, after installing shitty knockoff parts that dont fit worth a damn, followed up by poorly fitted cheap heavy wheels with the wrong offset so they rub but you play it off as looking cool, and then post pics here today"
Old Jun 1, 2004 | 05:55 PM
coleon's Avatar
RedNeck Refab.Inc
Well if I came off like a dick Im sorry, But I know the equation I need to answer, Not that you cant help me, but I as I hate to admit it, I do need some input, Input that I do not know at this time, and Im all for any reasonible solution, but as of now there is only one, reprogran my P72 to not see VSS or add a obdI cluster to my obd-0 car, either way I just want vtec to work. Hopefullly you can understand where Im comming from, if not, You will some time or another, but I t needs to work as if it was a 94 lude, not a rex. ya I can rig it, but whats the point..
Thanks Cole
Old Jun 1, 2004 | 06:00 PM
Josh's Avatar
Dr. Doom
n/p dude, i read it as you had a p72 with no VTEC, and that didn't make sense to me so i had to ask.
Old Jun 1, 2004 | 06:16 PM
coleon's Avatar
RedNeck Refab.Inc
it an 89 crx si - If that helps, w/ a 94 jdm H22a inserted in to it, Perfectly, for many different reasons, if I dont say so my self, Only because I put it in my self, and yes im kinda cocky about it, but I did it my self, and that's what in my book counts, I really sound like a dick, I know, I know, but I'd hope i could for ar least pertend a little bit, just a little bit if yall would allow me too.
I dont know all, I know this, but I'd like too!!!!
Old Jun 1, 2004 | 06:31 PM
coleon's Avatar
RedNeck Refab.Inc
whats the deal with a non obd1 accord cluster in a obdo car that would inhibit the scenairio to function as a obd1 vss
Old Jun 1, 2004 | 06:34 PM
na200whp's Avatar
Powered by BOOST
this post is wierd .are you looking for help or boasting about the work you did on your car.and for the record ,yes you sound like a dick.
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
