Help!!!! I'm going insane
I am only getting code 13 (engine temp. sensor) I don't think that will stop the car from starting but, I could be wrong. I set it to tdc on compression stroke and took off my valve cover and dizzy cap, the timing chain and gears are timed right and the rotor is set at cylinder one.
TR's resident A&P mechanic
I make a passive income from the comfort of my home, visit my blog, I would love to show you how to do the same
ISE Automotive-Mobile Mechanic and 24-7 Roadside assistance services from oil changes to full track car builds we do it all and get it done right the first time
Originally posted by hachibill
did you line up the oil pump/ distrbuter corectly, i know there is a certain way to do it and if everything is not the way is should be your car prolly won't run.
