Help!!!! I'm going insane
did you line up the oil pump/ distrbuter corectly, i know there is a certain way to do it and if everything is not the way is should be your car prolly won't run. maybe your computer is bad?
I didn't think about the ecu being bad, how would I be able to tell if it went bad? All of my gauges and lights work. I'm pretty sure my oil pump and dizzy are lined up right because I set the crank to tdc and the dizzy is sparking cylinder one.
TR's resident A&P mechanic
I make a passive income from the comfort of my home, visit my blog, I would love to show you how to do the same
ISE Automotive-Mobile Mechanic and 24-7 Roadside assistance services from oil changes to full track car builds we do it all and get it done right the first time
If you have fuel and spark and timmings right it should start ..
Your missing one of the key ingredients .
My guess is the crank is off from the cam and your timming is off .
Hondata saves lives
Hondata saves lives
My timing chain and gears are right, and my ignition timing is right, I'm thinking it's my ecu, does anybody have a once cam ecu that I can borrow or buy?
Originally posted by dr. octogon
pm me about the ecu.
If the fuel injectors were clogged, wouldn't the starter fluid still atleast start the motor?
Well the new ecu didn't work, it's still doing the same thing it just cranks and cranks, I can hear it firing but it just doesn't want to start. Theres gotta be some little thing that I'm looking over.
its the timing.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
reset the crank, chains and cam shaft to tdc. if it still does it turn the distributor a full rotaion (360*)
