twice cam KA FWD and RD the same?
the FWD head is meant for a head mounted distributor (like on hondas and such.) you could probably get away with changing the wiring harness. i wonder if the harness/ecu clips are the same.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
well if you have another car to drive then id say try and put the head on as is and all you have to worry about is the electrical wiring.
Originally posted by John
don't port KA heads makes them more fragile. All the top KA power people just do valve angle and pocket area adjustments.
-Eddie
-Eddie
