KA24E Piston Questions
Old Jul 12, 2004 | 04:51 AM
China's Avatar
Communist
Question KA24E Piston Questions
ive been to some different website that have various compression ratios for the SOHC 2.4L Nissan engines. im not sure if nissan came out with different engine internals for the different models (i doubt it), or if the websites dont know what they are talkin about (highly possible). any who help me out and throw me some numbers on the ka24e compression ratios. trying to figure out what pistons i should go with for a Ka24de-t project in the near future.
thanks
china
Old Jul 13, 2004 | 06:29 AM
buck19's Avatar
Forever Broke Nissan
dont use single cam pistons if youre going turbo. dont really want to mix boost and really high compression numbers.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Jul 13, 2004 | 09:42 AM
RubberBerner's Avatar
Sideways Maffia
the sohc pistons in the dohc is a 11:1 cr, i wouldn't run more than a 9.5:1 cr in a turbo ka.
NOBAMA!
Old Jul 13, 2004 | 09:48 AM
Sideways Maffia
oh as for the cr change in the sohc
Technical Information
Compression Ratio Change for 1989-90 S13's
According to Nissan Technical Bulletin TS89-072:
KA24E ENGINE CHANGE
APPLIED MODEL: 1989 240SX (S13) from engine number KA24-012039*
SERVICE INFORMATION
To improve driveability the KA24E engine on the applied model has been changed as follows:
Compression ratio has been changed (9.1 to 8.6).
Air temperature sensor has been added.
E.C.U. has been changed.
Idle speed.
Self-diagnosis for E.G.R.
*Vehicles with an Air Temperature Sensor on the air cleaner box have the
.modified engine.
NOBAMA!
Old Jul 13, 2004 | 11:54 AM
buck19's Avatar
wheres the engine number stamp?
Old Jul 13, 2004 | 12:12 PM
Sideways Maffia
right under the No. 3 spark plug on the block, right next to the Ka24 tag.
NOBAMA!
Old Jul 13, 2004 | 01:31 PM
China's Avatar
Communist
KA24E ENGINE CHANGE
SERVICE INFORMATION
Idle speed.
.modified engine.
i dont know how u found this but thanks.
china
Old Jul 13, 2004 | 01:33 PM
buck19's Avatar
which side of the block. never took notice
Old Jul 13, 2004 | 02:07 PM
Sideways Maffia
china
haha im good china, im good
NOBAMA!
Old Jul 13, 2004 | 02:10 PM
Sideways Maffia
well buck if its right under the #3 spark plug im guessing its on the driver's side (SOHC)
NOBAMA!
