KA24E Piston Questions
my plans are as follows:
1.) ka24e pistons into a ka24de block (lower compression for the turbos).
2.) s14 (96) 240 ka24de head onto step #1.
3.) ka24e/ka24de hybrid turbo project (possible garrett t3).
feedback, any additional ideas?
thanks
china
thanks
china
thanks
china
thanks
china
Originally posted by SuzukaSol
im going to go against the grain and build/turbo my sohc ka. helps that i have three engines to start with too. i dont see spending 4700 on an sr swap a good idea when i can have 2.4L of fully built turbo goodness under my hood for that price. and if i have probs ? parts are dirt cheap! if i fail ? ive lost nothing . if i suceed . i gain everything i wanted .
china
1. Why do you want the KA24E pistons again? By the time you add up pistons, rings, and machine work etc to make them work, for like $150 extra at the time of purchase you can get forged CP pistons! Start out with the correct application and correct compression ratio!
2. why bother with the 14 head? you had better come up with something good for this.
3. do a metal head gasket while you'er in there.
thanks
china
thanks
china
rest in peace tim.
rest in peace tim.
metal head gaskets are a lot easier to find for the dohc...and you'll need one of those.
i agree with matt about the pistons...its just smarter to get forged1 ones-engine will be much stronger.
for the head, i'd do a P&P, solid lifter conversion set to .010", and think about a light cam and stronger springs.
NOBAMA!
NOBAMA!
can u send me a link for the forged pistons? the cheapest i found ran alot of money, and i was better off swaping the ka for the sr.
thanks
china
you swap in the SOHC pistons for a higher compression setup.
go toka24de.com and phatka-t.com
buck19
buck19
buck19
buck19
china
you do want to lower it but this combination you are talking about is supposed to be high compression. i guess you havent seen the difference between the single and twin cam pistons.
the single cam pistons are almost flat all the way across and the twin cam pistons are more of a bowl. so the twin cam pistons would offer a lower compression ratio.
buck19
buck19
Buck is right China, the SOHC pistons offer too much compression for a boosted engine. i would just keep a stock bottom end if you can't afford to go for the forged pistons in the DOHC.
NOBAMA!
NOBAMA!
