Bryces car is finally running
Originally posted by joeyk
well you should have said that you put oil in the cylinders , this makes a big difference and is not the real way you should do a compression check but to free up rings in a shitty motor I guess it is ok.
no we oiled it the night before, manually cranked it and blow dried it. let it sit for the night. the next day we manually cranked again while blow drying and compression testted it after that and got those 230 psi numbers. so there shouldnt have been any oil in the cylinders.
P.S. the night before we compression tested it right after we oiled the rings and the numbers were lower than 230 and staggered all over the place.
and jillian. i wish i had money to buy another car. not sure if it would be a talon though.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
