Bryces car is finally running
nope thats not the once cam motor. it has just the 2 91 exhaust cams on an s14 motor. my motor put out about 220 psi when it ran. turns out it might just be the spark plug hole gasket since the one thats on it is hard and stale.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
theres nothing wrong with the gauge. since the motor was sitting for so long it put out extremely low numbers on a few cylinders. we oiled the cylinder walls and resat the rings and did another test with numbers on the low cylinders increasing by 100-120psi. then we let it sit over night and re-oiled and retested it the next day and got an even 230 psi.
jillian when are you going to have your car back on the road?
you should stop by sometime. havent seen you there in a while. i havent been there lately cause i actually have a job now. but we should be there for a few hours tonight and prob sunday afternoon as well. the bugs should be fixed by then along with bled brakes and power steering.
where'd ya get a job?....im going to start driving a straight truck for united soon, which should be interesting....i might make rounds on saturday after work, if your there around 5-6ish, ill be in the neighborhood
Poppa J. Smurf
Poppa J. Smurf
well after the talon is sold it will be 2 months after that...so its getting closer
~Jillian~
~Jillian~
at Tampa Bay grand prix. i work on and test the karts. we will be open to the public really soon. almost done with the timing system. im just fixing some bugs on the karts, but they are pretty damn fast. faster that anything around here. i should be at the garage around 7:30. rip the turbo off the semi at work. maybe your car sound even more like a diesel.
when did you get a talon?
well you should have said that you put oil in the cylinders , this makes a big difference and is not the real way you should do a compression check but to free up rings in a shitty motor I guess it is ok.
p.s bryce if you have anything to say behind my back why dont you just pm me and we can meet up.
