The correct way to build an s14.
Shelf parts are the sweet!
The best parts are in your "I wish I had the money for" Wishlist
Did you ever get that chassis harness worked out?
Greddy/Trust downpipe
Greddy VSPL kit with pipes
HKS SSQV bov with recirc insert?
Nissan full gasket kit box
96 grille
S14SR fuel rail
bike ITB/quad carb setup
S15 T28
S14SR throttle body
A box from Summit Racing
80mm maf sensor
some wiring
is that a water pump in that Nissan box?
test pipe
VTC cams
trans-exhaust bracket
front cover/oil pump
Waldo
2 sets of crutches
96 grille
S14SR fuel rail
S15 T28
S14SR throttle body
80mm maf sensor
some wiring
test pipe
VTC cams
Waldo
2 sets of crutches
Sponsored By Carrabba's
Sponsored By Carrabba'sR.I.P. Tim Aldrich
Is your sr stock bore? If so why the 87mm hg?
In retrospect that was a pretty retarded question...
dOH!
I wish I had an s14 head and could make the variable timing work with my s13 sr.
dOH!I wish I had an s14 head and could make the variable timing work with my s13 sr.
How much and what is the condition? shoot me a pm
