The correct way to build an s14.
Old Dec 28, 2009 | 06:27 PM
  #581 (permalink)
chome's Avatar
Will sleep for food.
Thats the feature I was looking for. Dumb point and shoot cameras cant but my SLR cant!
Old Dec 28, 2009 | 07:31 PM
  #582 (permalink)
LongFellow's Avatar
Please hold...
Yeah, I got lucky the turbo set up has less than 4k on it though it looks like it has 0.
I've been pretty lucky finding all kinds of deals on parts. Thats actually the reason why the motor isnt assembled. Every time I plan on buying the gaskets and valve retainers I end up finding awesome deals on stuff that would usually be 2x more expensive.
I should be getting my pre-wired engine harness in the next few days.
Team White Car 2010
Old Dec 28, 2009 | 08:28 PM
  #583 (permalink)
4wheeldriftS13's Avatar
February - Ride of the Month
Sweet!! and yeah that turbo looks like it has 0 miles on it lol
RIP Tim Aldrich
Old Feb 11, 2010 | 01:13 PM
  #584 (permalink)
Petes s13's Avatar
Any updates with the sr?
Old Feb 11, 2010 | 01:25 PM
  #585 (permalink)
LongFellow's Avatar
Please hold...
Soon.
Untill then play I spy with this picture.
Team White Car 2010
Old Feb 11, 2010 | 01:53 PM
  #586 (permalink)
B18C5-EG's Avatar
Carbs?
Old Feb 11, 2010 | 01:56 PM
  #587 (permalink)
Epstein's Avatar
Retired
Greddy/Trust downpipe
Greddy VSPL kit with pipes
HKS SSQV bov with recirc insert?
Nissan full gasket kit box
96 grille
S14SR fuel rail
bike ITB/quad carb setup
S15 T28
S14SR throttle body
A box from Summit Racing
80mm maf sensor
some wiring
is that a water pump in that Nissan box?
test pipe
VTC cams
trans-exhaust bracket
front cover/oil pump
Waldo
2 sets of crutches
Old Feb 11, 2010 | 02:23 PM
  #588 (permalink)
LongFellow's Avatar
Please hold...
Yeah thats the water pump. Though I'm surprised you missed the cosworth headgasket sitting under it.
Carbs are from my bike
Nismo Coppermix is wrapped in the shirt
Crankshaft is on the floor in news paper hidden mostly behind the boxes
Wire stuff is the complete SR wire harness MAF sensor is Z32 unit
There are about 30 other things hidden or in boxes so you can see them.
Team White Car 2010
Old Feb 11, 2010 | 02:30 PM
  #589 (permalink)
LongFellow's Avatar
Please hold...
Guess I'll make a list of everything going on the motor
S14 SR w/ VTC
NA S14 SR intake cam
S15 Spec R turbo
HKS Actuator
Trust divided outlet
Trust 80mil downpipe
3" test pipe
Stock manifold/heatshield
Custom 3" intake
Greddy VSPL FMIC
HKS SSQV2 w/ recirc
Nismo 550cc injectors
Nismo FPR & fitting
Cosworth 87mm x 1.1mm head gasket
OEM Piston rings
ACL Race bearings
Micro polished crank
OEM oil pump
OEM water pump
OEM gasket kit
OEM S15 7 layer exhaust gasket
Z32 MAF
Apexi Z32 Intake filter
Clutch fan & shroud
CX Racing radiator (only knock off part)
Nismo Thermostat
Walboro 255lph
Nismo Coppermix clutch
CodyAce A/C adapter bracket
Nissan Quest alternator
Gizzmo M-IBC
and some other random misc things I cant think of at the moment.
256/264 cams and a Exedy flywheel will be had later this year.
The idea is a fun all 280hp-ish car but with room to grow. So if I want to in the future I can go 2871 .64ar, 740cc injectors, tune and I'm at 360hp.
Team White Car 2010
Old Feb 11, 2010 | 02:47 PM
  #590 (permalink)
Petes s13's Avatar
Such a beautiful list.
