Return of the crankwalk
Old Jul 2, 2012 | 04:07 PM
Tom N's Avatar
Non DSM.....DSM guy
Default Return of the crankwalk
Well after about 9 months and a few thousand miles the evo 1 has crankwalked again.
I can move the crank in and out a good 1/4 inch.
I realy hate 7 bolts right now.
Tom
Old Jul 2, 2012 | 04:15 PM
THE_ONE's Avatar
*Turbo Interceptor*
Old Jul 2, 2012 | 05:41 PM
JR.'s Avatar
JR.
that sucks tom.
98 talon awd automagic
Old Jul 2, 2012 | 06:50 PM
omgosh's Avatar
"The thrust-force is strong in you, young crankwalker"
Seriously tho, that sucks...what clutch are you using out of curiosity?
Old Jul 2, 2012 | 07:03 PM
jdm-az's Avatar
HPC tuned / DRAG CARTEL
Lol. Stupidest girdle design known to man.
K*Squad
Old Jul 2, 2012 | 07:08 PM
Tom N's Avatar
Non DSM.....DSM guy
Clutch Master stage 1.
Tom
Old Jul 2, 2012 | 08:33 PM
wishiwasfast's Avatar
Will your fucked then.... 95 + 2600 = sell the car NOW!
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old Jul 2, 2012 | 09:00 PM
lancerman's Avatar
I almost hate to respond cause its the most mistunderstood subject on the net.
there are no cases of the factory built engine walking in less than 50k miles. most are much higher miles. there are plenty of threads of newly built engines walking in a few thousand miles. doesnt take a brain to figure out maybe the mechanic was at fault.
the simple culprit has a simple cure. 7 bolt cranks (including evo8/9) are not surface hardened from the factory. they spin bearings easily, and they crankwalk easily. I havent built a 7 bolt block in 7 years now without a nitrided crank. nitrided 7 bolts cranks are just as durable as 6 bolts.
any body that wants to argue about it will not get an arguemnet from me. I dont argue with stupid. so if you want to be stupid have at it.
my favorite quote
Old Jul 3, 2012 | 01:34 AM
Boost Demon's Avatar
Hate to hear that Tom. What do you plan to do now?
Old Jul 3, 2012 | 04:59 AM
THE_ONE's Avatar
*Turbo Interceptor*
How is not using a nitrided crank the mechanics fault? Oh well lol carry on!
