odd problem need some help...
Old Jun 13, 2012 | 05:25 PM
YBlegal's Avatar
Broke not Built
Default odd problem need some help...
ok so, first things first...
CAR is a 95 GST eclipse stock for the most part couple small bolt ons.
PROBLEM: The coolant temp gauge will read normal at idle, as soon as you give it a lil throttle wether in nuetral sitting still or under a load while driving the temp gauge will almost instantly start to rise like the engine would be over heating... but as soon as you let off the throttle and the rpms drop so does the temp gauge. like instantly...
now also the anti lock brake light comes on when the gauge starts to rise and goes off when the temp starts to drop...
i myself am baffled. ive never had a car do this before and i have somebody wanting to purchase the car but im not gonna sell it with these issues.
so if anyone has any insight to the cause of this issue please do share.
thanks in advane
working my way back up...
Originally Posted by JoKiE crx4294
What do i have to prove to anyone?....umm NOTHING!!
Old Jun 15, 2012 | 07:43 PM
omgosh's Avatar
If there is no coolant in the oil or vice versa...no smoke from the exhaust then I would check the wire for the coolant temp gauge at the sender. The plug (single wire near water neck) tends to break and come loose. Ive also had an axle eat through the wire harness and damage that wire. Also thermostat could be stuck or maybe the sensor is dirty.
Old Jun 16, 2012 | 09:30 AM
howeeez's Avatar
howie
Crankwalk!
cagedeyecam
Nissan/Infiniti Tech
5
Oct 26, 2010 03:52 PM
teamjdm239
May 27, 2009 12:59 PM
Aoshi
Jun 9, 2008 07:32 AM
low99civic
May 7, 2007 10:30 PM
Slash
14
Jan 21, 2004 08:17 PM
