Question
Old Nov 23, 2011 | 02:24 PM
Flaco_GST's Avatar
Master of the cut-off T'S
Default Question
Can somebody explain to me how in the world I put 17gal of gas in my Eclipse easy? 95-96 should have a 15.9 gallon tank right? Drove to the gas station, 17gal of gas went in and I'm pretty sure my car is a 16gal MAX if even that. Car didn't spudder going to the gas station and I check to see if it went into the hatch (Paranoid ed). No leaks and it doesn't smell like gas. Anybody has any ideas?
...Only god can judge me...
"If you don't set goals for yourself, you are
doomed to work to achieve the goals of
someone else."
Women might be able to fake orgasms but us men can fake a whole relationship.
V-TEC = Virtually-Torqueless Economic Cars
(PROG) Crew member #5
{o,o}
|)__)
O RLY?
Old Nov 23, 2011 | 03:21 PM
CODE4's Avatar
Tig Welder/Fabricator
Poorly calibrated fuel pump?
TIG Welder & Fabricator
Old Nov 30, 2011 | 12:53 PM
wishiwasfast's Avatar
The tanks are all 16.9 for 2g's. Plus alittle extra room for sloshing. When we pulled my FWD tank out it looked like it was below half full. I pulled over 8 gallons out.
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old Dec 2, 2011 | 05:17 PM
Flaco_GST's Avatar
95-96 are 15.9 gallon tanks. The 16 gallon tank are 97-99.
someone else."
{o,o}
|)__)
O RLY?
Old Dec 3, 2011 | 08:17 AM
GsEclipse02's Avatar
ill ride my gas light for 30 miles or so and ill only be able to put 13g of gas in ??? iguess i got more left in her ?
chask
Nissan/Infiniti Tech
25
Apr 13, 2009 01:19 PM
i275Phantom
Nov 10, 2008 08:51 AM
Signal7cbr!
Dec 8, 2007 03:10 AM
ZDriver96
Feb 12, 2002 01:01 PM
