Still need help...
yeah pretty sure its right then. there was a dot on the housing and a line on the paddle. thats just weird that it could just randomlly go bad after a motor rebuild? oh well, if i keep having the same problem i'm putting the spare cam sensor in and hopefully it fixes the problem. i'll let you guys know what the outcome is.
Still havn't changed out this cam sensor, but havn't had any problems since friday? Really weird. Any reason I'm getting HORRIBLE gas mileage? other than having a heavy foot? lol
Make sure you figure out the knock sensor issue before you beat on the car. Also check for boost leaks. If you're still running rich I would look into the O2 sensor and the coolant temp sensor.
Coolant temp is new, Pretty sure I don't have any boost leaks but I'm not promising anything. And yes I need to get a new knock sensor soon, should I buy a 2g knock sensor? I heard they were better?
It can, but IMO its not ideal. You should have another bung welded in the exhaust that is 24-36'' downstream in the exhaust. If you put the sensor back there to keep it from getting fried, then you are gonna have some lag during closed loop. Its kinda annoying.
