megan racing oil catch can install???
Old Mar 7, 2010 | 05:38 PM
  #21 (permalink)
CODE4's Avatar
Tig Welder/Fabricator
You could, but it would be accomplishing the same thing. What is your goal?
TIG Welder & Fabricator
Old Mar 7, 2010 | 06:09 PM
  #22 (permalink)
howeeez's Avatar
howie
so your saying that method i mentioned, would be the same method as a breather filter on th VC?
Old Mar 10, 2010 | 07:50 AM
  #23 (permalink)
howeeez's Avatar
howie
Exactly. You can either leave the breather filter on the side of the VC, or buy another catch can to take care of it.
By doing what you just described you are effectively trapping the oil vapor from being pulled from the VC into your intake manifold and eliminating the burning of oil and carbon build up on the piston tops and valves.
Now, if you had bought a vented catch can, like this one:
Excess Oil Accumulator (Catch Can) Kit Rev.3 : atpturbo.com
You would run both lines from the VC to the can and cap off the IM. This method allows to the crankcase vapors to vent to atmosphere (emissions illegal of course) while trapping any oil vapors in the can and allowing the driver to drain the can at intervals.
Since my catch can isn't vented . Could i tap a hole at the top of the can throw a nice fat nipple on there and put a breather filter on it? then i would be able to block of IM nipple and run the pvc hose to catch can and side vc hose to catch can . that would "technically" make it a Vented catch can am i right?
Old Mar 10, 2010 | 06:21 PM
  #24 (permalink)
CODE4's Avatar
Yes. I would make it pretty big though - along the lines of 3/4" NPT if using a pipe fitting or a 1" fitting to get a Mini K&N with a 1" flange on it.
