megan racing oil catch can install???
Old Mar 3, 2010 | 01:32 PM
howeeez's Avatar
howie
Default megan racing oil catch can install???
K guys I have been reading tons of threads still dont know the right way to hook up this megan racing oil catch can any help? link below of oil catch can.
EXTREME PSI : Your #1 Source for In Stock Performance Parts - Megan Racing Oil Catch Can *OVER STOCK SALE*
Old Mar 3, 2010 | 02:30 PM
CODE4's Avatar
Tig Welder/Fabricator
Depends on how you are using it. Are you attempting to install this between the IM and the VC? If so install it on the line from your PCV on the back of the VC.
TIG Welder & Fabricator
Old Mar 3, 2010 | 02:53 PM
howeeez's Avatar
howie
confused^, right now i have a breather filter on the pcv and on the backside of the valve cover the line is going in to IM.. How would i install that Megan racing oil catch can?
Old Mar 3, 2010 | 03:08 PM
CODE4's Avatar
Ok, where are you attempting to prevent oil transfer? Typically people install it between the PCV and the IM so that oil is not introduced into the intake.
Breather filters should not be on the PCV valve; they are usually installed on the vent side. The PCV line is routed to the IM so that the blowby is burned.
Old Mar 3, 2010 | 04:12 PM
kd42010's Avatar
from what i see you have two inlets on the catch can so mount the catch can, then run both the pcv valve and the other nipple on the valve cover to the catch can....
make sure you block off the hole on the intake manifold where the pvc was connected to.
theres only two places on the stock valve cover you can connect the catch can 2, so connect both of them.
hope this helps.
Old Mar 3, 2010 | 04:23 PM
CODE4's Avatar
hope this helps.
Negative.
If the catch can he bought was vented then he would run it this way. The can he linked to is not a vented one and would not serve any purpose if he hooked both lines off of the VC to it.
That particular model is meant to be inline between the VC and intake pipe, or VC and IM.
Old Mar 3, 2010 | 04:38 PM
kd42010's Avatar
^true...
mine is vented his is not, i guess i looked pass that.
Old Mar 4, 2010 | 03:25 AM
howeeez's Avatar
howie
k well there's 3 nipples on the catch can 2 at the top and 1 at the bottom. say those 2 nipples on top go between the IM and VC what would that 3 nipple at the bottom of catch can serve?
Old Mar 4, 2010 | 05:41 AM
Needfstwheelz's Avatar
^ HIGH...My Name Is
dont you hate that whenever you buy something online, the instructions are jappanese or dont come with any....
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
Old Mar 4, 2010 | 10:54 AM
kd42010's Avatar
wouldn't the nipple at the bottom be for draining?
