S-AFC info needed?
Old Apr 1, 2002 | 11:34 AM
Geisert's Avatar
Hey I have a 99 GSX and I am go to get a AFC but I was wondering if I show get it before I get a boost controler or after? Also if you have a S-AFC did you install your self and if you did was it a pain in the ass? Thanks for the help guys.
Old Apr 1, 2002 | 05:27 PM
TealTalon's Avatar
Dont bother with an AFC on the stock turbo. The S-AFC is usually best used with upgraded injectors. I would get a boost controller instead of the AFC. Unless you just like the blinky lights and are going to leave it all at 0 anyway....
If you must get an AFC then fine....I Installed one in my 2G and then took it out and put it in my 1G with a VPC. None are a PITA if you dont have to wear a football belmet to keep from denting your skull. Its just tapping a few wires before the ECU.
Old Apr 2, 2002 | 03:10 AM
Geisert's Avatar
So dont get a AFC until I get rid of the T-25 huh. Cool thats what I needed to hear so I am assuming that when I get the 16g I will be in need of one? Thanks man.
Old Apr 2, 2002 | 04:09 AM
TealTalon's Avatar
16G Front mount intercooler and some 550 injectors. Then you will need the AFC. For now just get the Boost controller and a fuel pump upgrade and play around with 17 pounds of boost or so.
Old Apr 2, 2002 | 04:33 AM
Geisert's Avatar
I have read that on a stock turbo after 14.5 pounds it damages the turbo and also have heard after 14.5 its just blowning hot air is this true?
Old Apr 4, 2002 | 09:02 AM
Chismoe's Avatar
Craving Boost
An AFC has enabled me to run faster than most guys with 16Gs and no AFC.
I would get the AFC before the turbo. When I got mine tuned right (with Erics help) I dropped a second off of my time. That one little piggy-back can help alot.
Mike i can order you one if you are ready just let me know.
Old Apr 4, 2002 | 10:00 AM
Geisert's Avatar
Good deal Ryan how much Ill have the funds for that in about a month and half. You think you can help me tune it? Let me know.
Old Apr 8, 2002 | 06:16 AM
Chismoe's Avatar
Craving Boost
Originally posted by "Someone"
Originally posted by 16gAWD
I dissagree. I run mid 12s on pump gas I have no AFC and stock injectors. Get a turbo that can handle 20#s of boost and you wont need the AFC. This is pretty much any turbo upgrade.
Sorry chismoe you will never beat me with your SAFC!
PS. I used to have one with my old setup and it worked great with upgraded injectors which I also had with my previous setup.
So youre the exception to the rule!
KJ
Feb 21, 2001 11:36 AM
sloaccord
Sep 6, 2000 06:54 AM
Bill
Jun 24, 2000 03:35 PM
