Won't Boost Above 5psi...It Just Sputters
Old Jun 15, 2009 | 03:29 PM
Ahhhh Nick!'s Avatar
Out Of Towner
Thumbs down Won't Boost Above 5psi...It Just Sputters
I've had this issue since I've owned the car and just assumed it was a boost leak since the previous owner did a hack job with the intercooler piping. Well I've replaced the intercooler piping with a set that's actually made for the car. I can feel it pick-up a little better, but I'm still unable to boost above 5psi. The car acts like it's hitting a fuel cut, it has a horrible misfire and won't pull through it. I can rev to redline but as soon as I get right around 5psi it just hits this wall. I haven't been able to get over 1/2 throttle without it doing this.
I've double checked my vacuum lines since those were also messed up when I purchased the car. I've been looking into getting rid of them, but haven't found the answers I'm looking for about that yet...
Where do I start? I hate this problem!
Here's a picture of my engine bay, maybe you can notice a big problem that I've looked over.
Old Jun 15, 2009 | 05:02 PM
Evil_GST's Avatar
Pure Evil
I have seen plug wires cause this... sometimes a little maintenance is all a car needs.
and recirculating the bov might help the car run better in general.
Old Jun 15, 2009 | 06:16 PM
bvh's Avatar
bvh
do u have a data logger?
Old Jun 15, 2009 | 06:23 PM
Johnnyboy3689282's Avatar
MOB 4 Life!!!
How long have u owned the car? I would also check your boost solenoid and your tune! Data logger would be Key, but sounds like a blown Turbo, is the car smoking when you go into boost?
Old Jun 16, 2009 | 04:21 AM
pure_power65's Avatar
Gone!!!
also check the wastgate actuator it might have come off if you have an internal WG, happened to my friend in his car i fixed it with a paperclip temporarily
& All Grip Racing
Old Jun 16, 2009 | 11:58 AM
bvh's Avatar
bvh
what do your plugs look like?
Old Jun 16, 2009 | 02:09 PM
omgosh's Avatar
^+1...
When I hooked my wideband up incorrectly (wideband 5v output to ECU narrowband 1v input) the AFR would peg out on the rich side of the gauge and the car would sputter/bog like mad as soon as it built any boost, but I could get it to rev with light throttle/no boost like you say.
Old Jun 16, 2009 | 10:29 PM
Needfstwheelz's Avatar
^ HIGH...My Name Is
man i had like the same problem...change your spark plugs first, thats all i needed. I did the wires first and problem stopped for a week...the plugs have been in for over a month andd car still pulls.
97 Mitsubishi Eclipse GST
95 Honda Civic ex coupe
95 Eagle Talon ESI
92 Mitsubishi Eclipse GSX
90 Acura Integra LS
94 Honda Civic ex coupe
90 Honda Civic std hatch
90 Acura integra LS
91 Acura Integra GS
98 Acura Integra RS
90 Acura Integra LS
93 Acura Integra RS
91 Acura Integra LS
90 Acura Integra LS
92 Acura Integra Gs-R
Old Jun 17, 2009 | 05:22 AM
BoostedTalon00's Avatar
DSMPowered
you said you redid your vacuum lines?? I looked at the engine bay pic and noticed some of them to the intake are disconnected. But if you fixed that, i would say possible boost leak, but you wouldnt be able to redline if it was that, and i would def replace your plugs
GOT LOVE FOR THEM DSM'S
Old Jun 17, 2009 | 06:37 AM
91TSI_AWD's Avatar
Resident Galant Guy
Check plugs, replace if needed, and Boost leak test the system. Any check engine lights?
Mike
95 Lancer GSR
93 300ZX 2+2
