Won't Boost Above 5psi...It Just Sputters
Old Jun 17, 2009 | 07:02 PM
  #21 (permalink)
Evil_GST's Avatar
Pure Evil
do a compression test, you might be getting to much blowby from worn rings if it's not a pcv issue. or you might just need a new dip stick. if you blow out a new dip stick your engine is probably due for a rebuild
Old Jun 18, 2009 | 01:42 AM
  #22 (permalink)
xxsupralvrxx's Avatar
its cheap an easy fix an its part of regular bullshit crap to buy advanced had them for 4.23 after tax for my 1g so I am sure its gonna be the same lol
Old Jun 18, 2009 | 02:07 PM
  #23 (permalink)
Ahhhh Nick!'s Avatar
Out Of Towner
I replaced my PCV valve and that solved the issue. Thanks guys.
Also cleaned up the engine bay a little, looks alot better IMO.
Old Jun 19, 2009 | 08:23 AM
  #24 (permalink)
BoostedTalon00's Avatar
DSMPowered
Looks cleaner, good job, did you paint the valve cover?
GOT LOVE FOR THEM DSM'S
Old Jun 22, 2009 | 06:12 PM
  #25 (permalink)
slowsohc's Avatar
Eat a dick
Originally Posted by Ahhhh Nick!
Problem fixed!
New spark plug wires, pulled 12psi off the wastegate just fine now.
I now have this new issue with the oil dip stick blowing up in high boost though...Ugh, it's always something.
Good deal. Theres always going to be something I learned that with all 3 of my DSM's. I still miss them though.
Old Jun 23, 2009 | 05:28 PM
  #26 (permalink)
Out Of Towner
Yea... I've learned that. I noticed I'm leaking a good bit of oil from my oil pump housing today. It hasn't done that since I've owned it. I need to get under there and check that shit out. There's always gonna be something wrong with it.
Old Jun 23, 2009 | 05:56 PM
  #27 (permalink)
Evil_GST's Avatar
Pure Evil
mine has been leaking from there since the beginning of time. when I took out the balance shafts I replaced ALL the seals on that side of the motor and it still leaks. I'm pretty sure now it's where the turbo drains meets the oil pan and it makes it's way over there. check your turbo oil drain, they always leak on these cars.
Old Jun 23, 2009 | 06:06 PM
  #28 (permalink)
Out Of Towner
Thanks, I need to check it out. I took a peak under and it looks like it's coming from one of the allen bolts that goes into the oil filter housing. I'll know for sure soon enough, wish it wasn't a 100 degrees out!
Old Jun 26, 2009 | 05:24 PM
  #29 (permalink)
stealthc9's Avatar
i know what the problem is... the ralliart oil cap FTL just kidding, spark plugs wires/plugs
**edit** u fixed the issue congrats
Originally Posted by Lime_Green_Hatch
i carry a gun because so many other losers and wanna be gangsters do.
Originally Posted by JH26
Morty,
The fact that I have red hair and no soul makes me very angry. I just wanted to let you know that when I swear and sling insults at you, its really because deep down inside, I hate myself. Please buy me some hair dye for my birthday.
