how good is this manifold??
But don't forget I do have a ebay manifold on the evo. Just took the proper steps to help prevent it from cracking. Been on the car almost a year with no problems.
JUDGE RACING
JUDGE RACING
The only way I would ever use tubular manifold on one of my cars is if a cast manifold was not available for the job. One of the most important jobs of a turbo manifold is preserving exhaust energy to drive the turbine. heat lost from manifold is big problem with tubular manifolds. they put tremendous amount of heat into engine compartment. engine bay temps can sky rocket. intake temps at filter go up with it. the evo world has done extensive testing in replacing stock manifold with tubular. take a close look and 95% of manifolds tested lost HP. and this was quick dyno pull test. add engine compartment heat and increased intake temps (not in evo testing) and test would have been far more revealing. stay cast if you can. I have a nice manifold for cheap for you if you are interested send me a PM for details
my favorite quote
my favorite quote
^ that would be interesting.. if you want good flow without worrying about cracking. turbonetics has a good cast tubular manifold. I have the buchar racing cast manifold, its been working well
Built 2.0L
ECMLINK
E85
BW S300ETT
& This GS-T hooks
All Built & Tuned by yours truly
In The Garage
- 99 Gst
- 91 Auto Talon
- 95 AWD TSI
& The DD,
a 07, S40 T5
Built 2.0L
ECMLINK
E85
BW S300ETT
& This GS-T hooks
In The Garage
- 99 Gst
- 91 Auto Talon
- 95 AWD TSI
& The DD,
a 07, S40 T5
Ive used 2 different cheap ebay tublular manifolds on N/A cars not making over 200HP and they eventually cracked. Cast w/heat shield FTW
< Forged internals with squirters stock. 14psi proof. It WILL be turbo'd, just not anytime soon.
