Help!! Temp Guage Reading Hot!!
Old Jun 26, 2007 | 08:09 PM
98_GstEclipse's Avatar
Already went there
Old Jun 26, 2007 | 08:10 PM
AnthrAxNSB's Avatar
first
You should definitely have someone experienced help you with this car before something goes awry.
Old Jun 26, 2007 | 08:11 PM
AnthrAxNSB's Avatar
first
Originally Posted by 98_GstEclipse
Already went there
In the last ten minutes? What did they say?
Old Jun 26, 2007 | 08:12 PM
I went yesterday. He told me to change out the thermostat and water pump
Old Jun 26, 2007 | 08:36 PM
AnthrAxNSB's Avatar
first
And then sent you on your way? I have to assume that the individual you spoke with understood your lack of experience after discussing the problem with you, and therefore I am curious as to why they're not working on your car. Did they at least give you a quote? Did you want to do this yourself? It's probably not a good idea for someone with your experience to replace a water pump on this motor. Take it somewhere.
cornflake's Avatar
813's Finest
check if your fans are coming on
Old Jun 26, 2007 | 08:39 PM
  #17 (permalink)
BOX SENTRA's Avatar
OG MUDBONE 240sx
the thermostat is probably getting stuck closed. i would start by putting a new thermostat in since its a cheap 5 minute job. if that doesnt fix it, then it might be time for a new pump, if it still doesnt fix it, something may be clogged up in your cooling system. im pretty sure you have to take the timing belt off to change the waterpump (ive always done both at the same time, so ive never tried to take a water pump off without the timing belt, and i think a timing belt tensioner pulley gets in the way) so if you arent comfortable with doing a timing belt, then basically dont touch it. i would start with the thermostat....thats honestly my best guess. it sounds like you are getting some flow, but it may be limited, because if you were getting no flow, turning the heater on wouldnt do anything.
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Jun 26, 2007 | 08:46 PM
  #18 (permalink)
AnthrAxNSB's Avatar
first
Originally Posted by DsmInduction
the thermostat is probably getting stuck closed. i would start by putting a new thermostat in since its a cheap 5 minute job. [...] you have to take the timing belt off to change the waterpump.
This is all correct. But, if one of "the brothers" said you needed a new water pump (as opposed to saying you might need a new water pump), and assuming they're as honest as their reputation suggests, you're going to need to take this somewhere, because I can only imagine what would happen if you tried to set the timing on this car.
Old Jun 26, 2007 | 08:47 PM
  #19 (permalink)
Im not gonna change the water pump myself. Im tryin to decide if I should just take out a loan and build a motor. I talked to Dave. Im always going to the brothers.
Old Jun 26, 2007 | 08:53 PM
  #20 (permalink)
The fans are coming on. Im gonna change the thermostat 2morrow. If that doesnt work im gonna have dave change the water pump
