Wastegate problem
Old Oct 4, 2006 | 06:53 AM
DSMboost97's Avatar
How long will it last?
Default Wastegate problem
Well i got bored today so i started to put on my new radiator hoses, and i decided to investigate the problem of why my wastegate didnt seem to be actuating. When i removed the actuator arm from the little thing that connects to the flapper i found that the flapper is sticking somehow. I cant even really explain the situation but you have to like jiggle it while trying to open it. sometimes it opens and sometimes it doesnt. What are my options to fix this? is it possible to replace just the flapper and the arm that controls it or do i have to get a whole new hot side of the turbo?
Old Oct 4, 2006 | 08:01 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
you might have to buy the whole actuator assembly, but the part thats sticking is the actual flapper inside the turbo?
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Oct 4, 2006 | 08:10 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
here i found this, it comes with the actuator, and the arm to the flapper, but i dont think it comes with the flapper...ill see if i can find a flapper. Mitsubishi OEM 14B/16G Wastegate Actuator
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Oct 4, 2006 | 08:28 AM
DSMboost97's Avatar
I cant really tell if its the flapper itself or the part that goes from the indide "through" the turbo to the outside that connects the flapper to the actuator arm.
Old Oct 4, 2006 | 08:43 AM
BOX SENTRA's Avatar
OG MUDBONE 240sx
you might have to take it apart to see if somethin is jammed, maybe spray some pbblaster in there and move it
-Dane
98 240 w/ bolt-ons
Srqspeed.com
Old Oct 4, 2006 | 09:32 AM
DSMboost97's Avatar
Well i moved it a round a bunch hoping that it would loosen up but it didnt really do anything. I adjusted the actuator arm so that when it is not extended, it is holding the wastegate open just a little bit but now the car wont run right. Its acting like i have a vented BOV, and everytime i let off the gas it stumbles and dies. im gonna try to adjust it back to the way it was to see if that is the problem.
Old Oct 4, 2006 | 09:59 AM
Tom N's Avatar
Non DSM.....DSM guy
I have a factory evo316g actuator you can have for $50.
Tom
Old Oct 4, 2006 | 04:11 PM
DSMboost97's Avatar
I think the actuator is fine, i think its trying to work but the flapper is so hard to move the actuator doesnt have enough power to get it to move.
Old Oct 4, 2006 | 04:22 PM
Tom N's Avatar
Non DSM.....DSM guy
You can hit the actuator with some air and see if it pops the arm out.
I have neard of the flapper getting stuck in some of those turbos. You will just need to take the housing off and look at it from the inside. Hopefully you are luckier than them.
Tom
Old Oct 5, 2006 | 02:25 AM
DSMboost97's Avatar
How do i do that? I know they have vaccum hand pumps but i think i remeber seeing a hand pump that created pressure instead of vaccum?
