14b limits
The gas smell is caused by the car running richer due to the air being metered is dumping back out. You also have a shitty bov that will leak once you start running real boost pressures.
15-17lbs is ok. Have you rewired your fuel pump too? If not, it would be a good idea too.
SUCH IS THE RULE OF HONOUR.
will the BOV hold the 14b at about 17lbs?
I want a greddy recirculating one once I get the money.
so throw on the 14b run 15-17lbs and ride out on stock injectors,tune and rewire fuel pump should be okay for a few months until I can get a AFC or another way of tuning the car?
will my BOV fuck any of this up?
will I get boost creep with my 3inch turbo back exhaust?
sorry for all the questions.. but do you think with the mods I'm throwing on 270whp is possible?
Totalled his shit!@
Totalled his shit!@
Manifolds rarely have anything to do with creep. You have a 14b, you wont have to worry about creep. Creep will start in the turbine housing around the wastegate port and with the o2housing.
take out the 3inch turbo back exhaust and get a 2 1/2 it would be better dsm under 450whp move better wit 2 1/2 than wit 3inch
You can see creep with a 3" turbo back and a 14b, but be patient and you won't have to worry about this sh*t.
IMO i would not advise to run that high of a boost level. just wait until you have all of the proper instruments to tune the car, and then proceed with the rest of the steps. and if you are trying to make any power out of the 14b you need bigger injectors. like some 550's or evo8 560's which are normally cheaper.
TEH WHIPS!!!
I have a BIKE 06 Cannondale Prophet.
2002 EP3 Civic SI
originaly posted by 57trim aka Jazz
MOTHERBITCHFUCKSHITDAMN!!!!!!!!...........DIIIIG!! ! BITCH!!! DIIIIG!!!
2002 EP3 Civic SI
Originally Posted by 98SOM_T/A
I ordered a 14b
I want to know how far I can push it with a 255lph walboro and stock ic
(255) is because its being sprayed later
I was thinking 17psi
btw 3inch turbo back exhaust, pulley, K&N cone filter and other shift I'm forgetting
Where did you order a 14b from is what I want to know.
Tom
Tom
EBAY
I payed 150 including shipping
not too bad, I've looked at a few local and they werent up to par for what they were asking. I've dealt with the guy on EBAY personallly before and I trust him.
I payed 150 including shippingnot too bad, I've looked at a few local and they werent up to par for what they were asking. I've dealt with the guy on EBAY personallly before and I trust him.
Totalled his shit!@
Totalled his shit!@
