Post Dream Setups
Heres my dream setup!
Car:
-White 98 TSI AWD w/all black interior!
Rims/Tires:
-16x7.5 Rota Subzeros 225-50-16 Falken Ziex 512
-17x7.5 Rota Slipstreams 235-45-17 Falken Ziex 512
Suspension/Brakes:
-Tein Flex Coilovers w/EDFC, full suspension bushing kit, sway bars, tie bars, strut bars
-Front Wilwood 4POT Calipers with 13.5" rotors Rear 2POT caliper with 12.5" rotors
Motor/Tranny:
-Bottom end
*7 bolt 2.3 Stroker with Crower rods, JE 7.5:1 compression STD bore, Nitrided crank, EVO 8 oil squirters.
-Top end
*Port/Polish/Flow bench 2G head, 1mm oversized intake valve, EVO 8 exhaust valves, upgraded valve springs/retainers, FP2 cams, Fidanza cam gears, Cyclone manifold w/wastegate actuator mod
-Shep race spec built tranny & t-case
-Gator Stage 5 axles
-Light weight driveshaft
Turbo setup:
-Full Race T4 EL manifold
-T4 GT35R w/4" ported shroud
-Tial 44mm V-band wastegate
-Tial 50mm BOV
-Custom 3" V-band o2 housing
-Custom 3" V-band downpipe
-Custom 3" Turboback exhaust
Cooling:
-SBR 2G Race FMIC kit
-Fluidine Radiator
-Dual Flexilite fan setup
-Evans cooling
Electronics:
-AEM EMS w/5 bar map sensor and IAT sensor (speed density)
-GM boost selenoid
-Dell Laptop
-Defi BF link system
-Defi BF Boost
-Defi BF EGT
-Defi BF Fuel Pressure
-Defi BF Oil Pressure
-Defi BF Water Temp
I am sure the misc stuff is missing, but you get the point.
And to top the dream setup, I would also love to have an 06 IX MR weightless white for a daily driver. Life would be good!
Car:
Rims/Tires:
Suspension/Brakes:
Motor/Tranny:
-Bottom end
-Top end
Turbo setup:
-Tial 50mm BOV
Cooling:
-Fluidine Radiator
-Evans cooling
Electronics:
-GM boost selenoid
-Dell Laptop
-Defi BF Boost
-Defi BF EGT
-Defi BF Water Temp
My dream set-up is one that I actually stick with
...ha beat you guys to it
But mostly for mine to run good without leaks or issues!
