2g cams and 1g cams
Wanting to know if there is any differences in the 1g and 2g cams? And can you put 2g cams on a 1g head.
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Why not just use 1g cams on a 1g head? Im not sure of the differences, but the 1g's are power proven, and if you need some i got some for you.
SUCH IS THE RULE OF HONOUR.
I was waiting for you to chime in Tom...I have some 91's with low miles.
i was asking for a friend who has a 1g head but has 2g cams can it be done? I dont see why it cant but then again i dont know thats why i am asking.
The differences between the stock turbo cams are so small that it's not worth the trouble of swapping them. I was lucky enough to have the best combination, the D C cam combo with the most advantageous duration and lift specs, but the difference between that and turbo auto cams is probably 5 hp.
If you want a better cam within the stock rev range, look at an FPCAM1. Improved torque throughout the stock rev range. If I ever upgrade I'm going with a set of the FPCAM1.
