timing
Old Apr 23, 2005 | 05:27 PM
dsmtuner's Avatar
gotta love the boost
Default timing
heres the deal i put a oil pump on the 4g63 put when i timed it and then started it it is missing like it is a tooth off but i checked my marks and the all are right on,well the crank was a little off but you cant pull a tooth out of the adjustment. any thoughts. thanks.
SVT F150
Old Apr 23, 2005 | 05:37 PM
Tom N's Avatar
Non DSM.....DSM guy
What do you mean the crank was off a little???
Tom
Old Apr 23, 2005 | 05:40 PM
dsmtuner's Avatar
ok the book said for 1990-1992 you use the timing mark by the oil pump. well when i timed the motor i had to turn the crank pully a little so the belt will slip on. it was barely off but noticable i dont remember exactly how much off.
SVT F150
Old Apr 23, 2005 | 05:53 PM
Tom N's Avatar
Non DSM.....DSM guy
Line up your marks to top dead center. Then turn the crank over six times and see if all the marks are still lined up at top dead center.
Tom
Old Apr 23, 2005 | 05:56 PM
dsmtuner's Avatar
alright and if they are not what is your suggestion. retime it,again
SVT F150
Old Apr 23, 2005 | 05:58 PM
Tom N's Avatar
Non DSM.....DSM guy
Take your belt off and do it right.
Tom
Old Apr 23, 2005 | 06:00 PM
dsmtuner's Avatar
ok i will see what i can do monday. thanks
SVT F150
Old Apr 23, 2005 | 06:04 PM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
UMmmm....i going to go out on a limb here, but did you loosen up your tensioner? to redo the timing or did you just slide the belt off and are trying to slide it back on? You can do that if you have skills, but if your not sure on what your doing the timing will be off, and it wont line up correctly.
SUCH IS THE RULE OF HONOUR.
Old Apr 23, 2005 | 06:07 PM
dsmtuner's Avatar
well my brother loosened the bolt that holds the pully assembly on we put the belt on then we pryed it on and tightened it.
SVT F150
Old Apr 23, 2005 | 07:05 PM
Stephan's Avatar
if you have a 1g go here http://www.vfaq.com/mods/timingbelt-1G.html if you have a 2g go here http://www.vfaq.com/mods/timingbelt-2G.html.....that will tell you everything you need to know....for the MD998738 bolt just use the long alternator bolt....
DSM Part Out
joshy
Jul 20, 2006 11:16 AM
xxpitxxxbullxx
Apr 10, 2004 08:41 AM
spoonfed
Feb 22, 2004 08:01 AM
Fermunky
Nov 19, 2003 10:42 AM
99B16Si
Mar 30, 2002 06:52 AM
