Cams, Cam Gears, Timing Belt
Old Apr 7, 2004 | 06:26 AM
xxpitxxxbullxx's Avatar
Midnite Assassyn
Default Cams, Cam Gears, Timing Belt
i will be changing the cams in my 92 LS, i will be using crower 403's i want to change cam gears but i dont know wut to use, and people have been saying i need to change my timing belt is this tru or wut? is there an after market timing belt that yall would perfer to you or use an OEm honda timing belt lemme know .... thanks.....
Old Apr 7, 2004 | 06:39 AM
99B16Si's Avatar
if your timing belt shows excessive wear on the teeth its definitely time to replace it. and its also recommended that it gets changed ever ~80k miles. it would be a it easier to do it when u install the cames because ud be half way there anyway. oh and just use an oem
Old Apr 7, 2004 | 09:10 AM
Bill's Avatar
Livin' in Seattle
Stock is fine though Toda and PE offer stronger replacements.
I also hope you have a Helms manual and a good low range torque wrench if you plan on doing it yourself.
Old Apr 7, 2004 | 09:50 AM
Midnite Assassyn
how much does it coast to get that done?
Old Apr 7, 2004 | 09:55 AM
mtber's Avatar
Use a oem timing belt, you will be fine.
The only time you really need an upgraded timing belt is when you run heavy duty valve springs & cams combined.
Camshaft installation usually costs anywhere from $150-250 at most shops depending on weather or not you are changing your timing belt also.
Old Apr 7, 2004 | 10:25 AM
Midnite Assassyn
i am gonna do it all at once cams, cam gears and belt would you prefre to change the belt just incase ?
Old Apr 7, 2004 | 11:07 AM
specie's Avatar
Might as well get it done. Are you changing valve springs also?
Old Apr 7, 2004 | 12:28 PM
Midnite Assassyn
nope i am just doing cams cam gears a timing belt
Old Apr 7, 2004 | 10:06 PM
InsaneCivicCoupe's Avatar
Retired Ricer...
so you are installing the 403 cams with your stock valvetrain????
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
