Eclipse Died
Old Mar 29, 2005 | 06:35 PM
dsmtuner's Avatar
gotta love the boost
check the battery first its the easiest thing to come out first, i will bet it is the battery,when you take the jump cables off does it die.
SVT F150
Old Mar 30, 2005 | 07:04 AM
Kristin's Avatar
call me Gangsta boo
Yep battery first, then mess with the alternator. Don't count on the cheap little Auto Zone test either. They told me my alternator was fine twice.....when it wasn't. I spent 2 weeks checking every wire, fuse and pulling out my subs to figure out what my problem was....just to find out it WAS my alternator.
Please check out this link...
http://www.BeautysEquineRescue.org
Old Mar 30, 2005 | 07:08 AM
JDMBlackGSR's Avatar
Gators Bitches!
Its not the Battery....i have tested it already and stated that in the thread 3 times. It was jumped and with the jumper cables on it, it still dies. The car started with the cables on it then died immediately without removal of the cables.
Old Mar 30, 2005 | 08:57 AM
dsmtuner's Avatar
If your battery is good, then chances are it isnt your alternator either... if you have a battery pumping out 10-12 volts the car should still run....... Sounds as though you may have something else wrong with it... try starting the car and seeing if you can hear the fuel pump buzzing through the gas tank fill up tube.. one less thing to worry about. If you dont hear the fuel pump it may be your problem...
SVT F150
Old Mar 30, 2005 | 09:11 AM
Gators Bitches!
alright, i will check that, I am gonna check everything over tonight....ie. ignition system, spark plugs and stuff then the alternator
Old Apr 2, 2005 | 10:12 AM
Gators Bitches!
Ok, so I got a new battery, spark plugs, wires, and had the alternator tested/cleaned at an alternator shop, and it is producing what it is supposed to. I checked the ground wire and all the fuses and still will not run. Any other suggestions?
Old Apr 2, 2005 | 10:23 AM
  #17 (permalink)
Ep41382's Avatar
TR Balla Donor Supreme
is the engine getting fuel? fuel pump? maybe there is a kink in the line somewhere... um...
Eric
AIM: Ep41382
Old Apr 2, 2005 | 10:29 AM
  #18 (permalink)
Gators Bitches!
whatup eric, its chuck.....i just read about that, so I am gonna check that stuff now.
Old Apr 2, 2005 | 09:02 PM
  #19 (permalink)
Ep41382's Avatar
Chuck? do i know you?
Eric
AIM: Ep41382
type R
War Stories
6
Aug 3, 2003 05:06 PM
fastforward
War Stories
25
Mar 27, 2003 06:52 AM
dsmturbo
War Stories
88
Feb 10, 2003 12:37 PM
