need ignition help - eclipse
Old Feb 17, 2005 | 09:38 AM
russellbeermann's Avatar
F*ck da rent, get the Lex
i don't know if this matters, but we had tried flipping the cam position sensor, but ran the same in either direction. does this matter which way it is flipped?
Russ
03 Infiniti G35
01 Lexus IS 300
99 Acura TL - for sale
96 Honda Civic DX - for sale
Old Feb 17, 2005 | 09:55 AM
if anyone out there has a 1g head on a 2g block, all i would have to do is copy their setup
Russ
03 Infiniti G35
01 Lexus IS 300
Old Feb 17, 2005 | 05:27 PM
dsmtuner's Avatar
gotta love the boost
you flipped it your talking about the adjustable one coming right off the head right . well if so flip it around thats your timing your messing with flip it and run the firing order that i said and see what happens.
SVT F150
Old Feb 17, 2005 | 05:36 PM
the reason why we flipped it was becuase the machine shop may not have put it back the correct position. thanks to boostb4broads, i have the right firing order, so i just need to double check that the sensors are right and that i don't have dirty injector harnesses
Russ
03 Infiniti G35
01 Lexus IS 300
Old Feb 17, 2005 | 06:01 PM
dsmtuner's Avatar
Might want to double check the cam timing too, if nothing else fixes it, two different sets of crankshaft timing marks depending on it being a 6 or 7 bolt crank.
SVT F150
Old Feb 18, 2005 | 04:54 AM
Ian MMF's Avatar
Omnipotence
Sorry I didn't get a chance to reply to your IM last night Russell I have a female friend staying in town with me so I had to "take care" of her.
If you need some more help shoot me a PM.
Old Feb 18, 2005 | 07:19 AM
  #17 (permalink)
lol...its all good. me and chris (mightmaxgst) tried that firing order boostb4blondes (thanks buddy) gave me and it worked. the other problem i had was that i didn't have a good ground connected to the head. now, the new problem is, my idle shot up to 4000 rpm's when we got a good ground on it. the idle adjusting screw was all the way closed that the idle was set to the lowest setting on the vpc/gcc. chris was saying that since my battery was on the verge of being dead, it could be messing with the idle. what do you guys think?
Russ
03 Infiniti G35
01 Lexus IS 300
Old Feb 18, 2005 | 08:15 AM
  #18 (permalink)
MightyMaxGS-T's Avatar
not that the battery is on the verge of being dead, the battery is bad that's why the grounds arent good, and that's the firing order we used to begin with russell....
PM me for any AC, audio, and wiring work on your vehicle. Including but not limited to car audio, alarms, gauge installs, custom clusters, full troubleshooting, big/dual fuel pump relay kits, battery relocation, factory radio iPod and amplifier integration, custom harnesses, and custom standalone ecu installs and much more! If you need it done, we can do it! Don't be afraid to inquire!
813kr$
Mazda Tech
May 21, 2004 05:28 AM
813kr$
Mazda Tech
4
May 21, 2004 05:22 AM
BLUE2KSS
Feb 26, 2004 11:19 AM
