Need Help
Old Sep 7, 2004 | 02:25 PM
boosteddsm's Avatar
Awd the enemy of fwd
Default Need Help
I need any info from anyone just dont come back say try this if i already have tried it. Every time i start the car it idles irraticly and then stalls, and if i give it any gas at all it will just break up. I already changed the fuel pump, that was not the problem, changed the maf, that was not the problem, changed the spark plugs, not the problem!!!!! I dont know what to do, I was told that it was very possible that the ecu might have gone bad, I have checked all my sensors and they seem to be good as well. I was told that there i some around here that works on the dsm ecu`s if there is i would like to get in touch with him. And the problem that goes on the ecu`s are the compacitor, but i dont know shit about computer boards need help, nopi is comin in 11 days gotta get this fixed thanks for any help recieved..
2 Step @ 1.5 bars..... Who wants some
And I thought that AWD is to have traction.
Old Sep 7, 2004 | 02:33 PM
16ggst's Avatar
Shut up
what mods do you have if any???
Old Sep 7, 2004 | 02:38 PM
TBSpyder's Avatar
Does your mas have all the honeycombs in it?
Old Sep 7, 2004 | 02:42 PM
Stealth's Avatar
Col. John Hannibal Smith
Have you checked all the plug wires / dist.?
Old Sep 7, 2004 | 02:45 PM
boosteddsm's Avatar
yeah mas has all honeycombs in it, turbo back exhaust n1 2.27 down pipe 3'' back, greddy uip and 1g bov, s-afc tuned by jerry, rx-7 twin turbo fuel pump, stock turbo runnin 16 psi, and k&N Filter...
Old Sep 7, 2004 | 02:50 PM
boosteddsm's Avatar
just put new wires on 2 weeks ago or so they are fine. Dist???? No thats not the problem. Distributerless ignition coil pack.. NO im getting good spark..
Old Sep 7, 2004 | 02:51 PM
16ggst's Avatar
Shut up
stock injectors?
Old Sep 7, 2004 | 02:56 PM
boosteddsm's Avatar
yeah stock injectors but before you say its the pump it was doing this before i put that pump in.. Thats why i tried this one to eliminate the idea of it being the fuel pump.
Old Sep 7, 2004 | 03:14 PM
czech09's Avatar
check your inc piping and make sure it's connected - I remember a while back aaron on here had almost the same problem, and tried everything for like a month and then it ended up being his lower inc pipe was disconnected...
Old Sep 7, 2004 | 03:30 PM
boosteddsm's Avatar
yeah ill check that out, but i dont think that, that would make your car stall as soon as you turn it over would it??
