mod help
Old Aug 21, 2003 | 05:18 PM
EclipseRSTurbo's Avatar
oh ya, thanks for the heads up, i'd rather not think about that.
Ya its an RS-T. they only make them in Japan
Old Aug 21, 2003 | 05:29 PM
psifactor's Avatar
Hello
if you play it safe...it wont blow up.
just do things right and you wont have that problem right away.
do your fuel system..I have spare 450cc's and 550cc's right now.
Who put the turbo on your car?
what is the lph of your fuel pump?????
Heavy car with a 2.5L
Old Aug 21, 2003 | 05:31 PM
believe it or not but mitsubishi put it on for me, and i forgot what the lph was..sry
Old Aug 21, 2003 | 05:42 PM
psifactor's Avatar
Hello
did they make a turbo kit or is it something that you bought.
you are very vague in your post. well..you probably need at least a fuel pump in the 190 to 255lph range. Walbro makes some good pumps.
What all did the turbo kit come with that they put on..or did they make you a kit.
I read the other post about the intercooler. has you car been over heating at all?
Old Aug 22, 2003 | 01:59 PM
ya it the hahn race craft kit
Old Aug 24, 2003 | 06:45 PM
sentra of attention's Avatar
Jose
just a question
rich=too much fuel and lean=not enough fuel, right?
for the 420a how much fuel would be too much, or could you look at the a/f ratio and just adjust it w/ proper tuning?
Old Aug 24, 2003 | 07:09 PM
  #17 (permalink)
psifactor's Avatar
Hello
You are correct in saying Lean = Not enough fuel and Rich = too much.
as far as a 420A it all depends on what your set up is.
a/f ratio guage is just about useless when it comes to tuning. The a/f ratio readings come off of the O2 sensor which gives you too narrow of a range.
Old Aug 24, 2003 | 07:15 PM
  #18 (permalink)
Jose
ok so if im running to rich how would i fix it?
Old Aug 24, 2003 | 08:28 PM
  #19 (permalink)
Skillionaire's Avatar
Nobody
You wont need any extra fuel unless you go turbo or nitrous. A bad O2 sensor can cause you to run rich
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Aug 24, 2003 | 08:33 PM
  #20 (permalink)
Jose
ok
