Mazda check engine light codes.
Old Nov 30, 2011 | 08:49 AM
CoRDiTe's Avatar
Not Mad
Default Mazda check engine light codes.
Here is a list of Engine codes for Mazda vehicles. Found this list on google.com. I do not take any credit for these. I found them and organized them into groups to make it easier to find your code.
Manufacturer Specific Codes P1000 to P1130
P1000 OBD II Monitor Testing Not Completed
P1001 Unable to Achieve Self-Test Function Or SCP Error
P1100 Mass Air Flow Sensor Circuit Intermittent -
P1101 Mass Air Flow Sensor Circuit Out Of Self-Test Range
P1102 Mass Air Flow Sensor Signal Inconsistent With Throttle Position Sensor
P1103 Mass Air Flow Sensor Signal Inconsistent With Engine Speed
P1110 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit
P1112 Intake Air Temperature Sensor Circuit Intermittent -
P1113 Intake Air Temperature Sensor Signal (Dynamic Chamber) Circuit
P1114 Intake Air Temperature Sensor Circuit Low Input
P1116 ECT Sensor Circuit Out Of Self Test Range
P1117 ECT Sensor Signal Intermittent
P1120 Throttle Position Sensor Out Of Range Low
P1121 Throttle Position Sensor Signal Not Consistent With Mass Air Flow Signal
P1122 Throttle Position Stuck Closed
P1123 Throttle Position Stuck Open
P1124 Throttle Position Sensor Signal Out Of Self Test Range
P1125 Throttle Position Sensor Signal Intermittent -
P1126 Throttle Position (Narrow Range) Sensor Circuit -
P1127 HO2S Bank 1 Sensor 2 Heater Not On During Key On Engine Running Self Test
P1128 HO2S Bank 1 Sensor 1 Signals Swapped In Key On Engine Running Self Test
P1129 Downstream H02S Sensors Swapped
P1130 HO2S Bank 1 Sensor 1 Not Switching (Fuel Control Limit Reached)
Manufacturer Specific Codes P1131 to P1138
P1131 HO2S Bank 1 Sensor 1 Signal Below 0.45v (A/F Ratio Too Lean)
P1132 HO2S Bank 1 Sensor 1 Signal Above 0.45v (A/F Ratio Too Rich)
P1133 Bank 1 Fuel Control Shifted Lean
P1134 Bank 1 Fuel Control Shifted Rich
P1135 HO2S Bank 1 Sensor 1 Heater Circuit Low Input
P1136 HO2S Bank 1 Sensor 1 Heater Circuit High Input
P1137 HO2S Bank 1 Sensor 2 Not Switching (Fuel Control Limit Reached)
P1138 HO2S Bank 1 Sensor 2 Signal Above 0.45v (A/F Ratio Too Rich)
Manufacturer Specific Codes P1141 to P1150
P1141 HO2S Bank 1 Sensor 2 Heater Circuit Low Input
P1142 HO2S Bank 1 Sensor 2 Heater Circuit High Input
P1143 HO2S Bank 1 Sensor 3 Signal Below 0.45v (A/F Ratio Too Lean)
P1144 HO2S Bank 1 Sensor 3 Signal Above 0.45v (A/F Ratio Too Rich)
P1150 HO2S Bank 2 Sensor 1 Not Switching (Fuel Control Limit Reached)
Manufacturer Specific Codes P1151 to P1154
P1151 HO2S Bank 2 Sensor 1 Signal Below 0.45v (A/F Ratio Too Lean)
P1152 HO2S Bank 2 Sensor 1 Signal Above 0.45v (A/F Ratio Too Rich)
P1153 Bank 2 Fuel Control Shifted Lean(FAOSC)
P1154 Bank 2 Fuel Control Shifted Rich (FAOSC)
Manufacturer Specific Codes P1169 to P1189
P1169 HO2S Bank 1 Sensor 1 Circuit Fixed (Bank 1 Sensor 1)
P1170 HO2S Bank 1 Sensor 1 Circuit Fixed (Bank 1 Sensor 1)
P1173 HO2S Bank 2 Sensor 1 Circuit Fixed (Bank 2 Sensor 1)
P1182 Fuel Shut Off Solenoid Circuit
P1189 Pump Speed Signal
Manufacturer Specific Codes P1190 to P1197
P1190 Calibration Resistor Out Of Range
P1191 TP (Controlled) Circuit
P1194 ECM, PCM, A/D Converter
P1195 EGR Boost Sensor Circuit
P1196 Ignition Switch Start Circuit
P1197 Mileage Switch Circuit
Manufacturer Specific Codes P1213 to P1250
P1213 Start Injector Circuit
P1221 Traction Control System
P1222 Traction Control Output Circuit
P1226 Control Sleeve Sensor Circuit
P1235 Fuel Pump Control Circuit
P1236 Fuel Pump Control Out Range
P1248 Turbo Boost Pressure Not Detected
P1250 Pressure Regulator Control Solenoid Circuit
Manufacturer Specific Codes P1252 to P1298
P1251 Air Mixture Solenoid Circuit
P1252 Pressure Regulator Control Solenoid '2' Circuit
P1260 Anti-Theft System Signal Detected - Engine Disabled
P1270 Engine RPM or Vehicle Speed Limit Reached
P1279 Control Sleeve Sensor Circuit Range/Performance
P1298 Injector Driver Module Failure
Manufacturer Specific Codes P1309 to P1345
P1309 Misfire Detection Monitor
P1312 Injection Pump Timing Actuator Circuit
P1318 Injection Timing Piston Position Sensor Circuit
P1319 Injection Timing Piston Position Sensor Circuit Range/Performance
P1345 No CMP or SGC Signal
Manufacturer Specific Codes P1351 to P1359
P1351 Ignition Diagnostic Monitor Signal Lost To PCM Or Out Of Range
P1352 Ignition Coil 'A' Primary Circuit
P1353 Ignition Coil 'B' Primary Circuit
P1354 Ignition Coil 'C' Primary Circuit
P1358 Ignition Diagnostic Monitor Signal Out Of Self Test Range
P1359 SPOUT Signal Lost To Powertrain Control Module Or Out Of Range
Manufacturer Specific Codes P1360 to P1390
P1360 Ignition Coil 'A' Secondary Circuit
P1361 Ignition Coil 'B' Secondary Circuit
P1362 Ignition Coil 'C' Secondary Circuit
P1364 Ignition Coil Primary Circuit
P1365 Ignition Coil Secondary Circuit
P1382 Camshaft Position Timing Solenoid #1 Circuit
P1387 Camshaft Position Timing Solenoid #2 Circuit
P1390 Octane Adjust Shorting Bar Out or Circuit Open
Manufacturer Specific Codes P1400 to P1410
P1400 DPFE Sensor Circuit Low Input
P1401 DPFE Sensor Circuit High Input
P1402 EGR Valve Position Sensor Circuit
P1405 DPFE Sensor Upstream Hose Off Or Plugged
P1406 DPFE Sensor Downstream Hose Off Or Plugged
P1407 No EGR Flow Detected
P1408 EGR System Flow Out Of Key On Engine Running Self Test Range
P1409 EGR Vacuum Regulator Solenoid Circuit
P1410 EGR Boost Solenoid Valve Stuck
Manufacturer Specific Codes P1412 to P1419
P1412 Exhaust Gas Re-circulation Valve Frozen
P1415 Air Pump Circuit
P1416 Port Air Circuit
P1417 Port Air Relief Circuit
P1418 Split Air #1 Circuit
P1419 Split Air #2 Circuit
Manufacturer Specific Codes P1439 to P1450
P1439 Floor Temp Switch Circuit
P1443 EVAP System Purge Flow Fault
P1444 EVAP Purge Flow Sensor Circuit Low Voltage
P1445 EVAP Purge Flow Sensor Circuit High Voltage
P1446 Evaporative Vacuum Solenoid Circuit
P1449 Evaporative Check Solenoid Circuit
P1450 Unable To Bleed Up Fuel Tank Vacuum
Manufacturer Specific Codes P1451 to P1479
P1451 Canister Vent Solenoid Circuit
P1455 Fuel Tank Level Sensor Circuit
P1456 Fuel Tank Temperature Sensor Circuit
P1457 Purge Solenoid Control System
P1460 Wide Open Throttle A/C Cut-Off Relay Circuit
P1464 Air Conditioning Control Signal Circuit
P1473 Fan Circuit Open (VLCM)
P1474 Fan Control (Primary Winding) Circuit
P1475 Fan Relay (Low) Circuit
P1476 Fan Relay (High) Circuit
P1477 Additional Fan Relay Circuit
P1479 Fan Control (Condenser Primary) Circuit
Manufacturer Specific Codes P1485 to P11499
P1485 EGR Vacuum Solenoid Circuit
P1486 EGR Vent Solenoid Circuit
P1487 EGR-CHK (Boost) Solenoid Circuit
P1491 Secondary Switch Solenoid Circuit
P1492 APLSOL Solenoid Circuit
P1493 RCNT Solenoid Circuit
P1495 TCSPL Solenoid Circuit
P1496 EGR Valve Motor Coil '1' Open or Shorted
P1497 EGR Valve Motor Coil '2' Open or Shorted
P1498 EGR Valve Motor Coil '3' Open or Shorted
P1499 EGR Valve Motor Coil '4' Open or Shorted
Manufacturer Specific Codes P1500 to P1515
P1500 Vehicle Speed Sensor Intermittent Signal
P1501 Vehicle Speed Sensor Out Of Self Test Range
P1502 Vehicle Speed Sensor Circuit Error
P1504 Idle Air Control Solenoid Circuit Intermittent
P1505 Idle Air Control System At Adaptive Clip
P1506 Idle Air Control System Overspeed Detected
P1507 Idle Air Control System Underspeed Detected
P1508 Bypass Air Solenoid '1' Circuit
P1509 Bypass Air Solenoid '2' Circuit
P1510 Idle Signal Circuit
P1511 Idle Switch (Electric Control Throttle) Circuit
P1512 VTCS Fault
P1515 Electric Current Circuit
Manufacturer Specific Codes P1521 to P1540
P1521 VRIS Solenoid '1' Circuit
P1522 VRIS Solenoid '2 Circuit
P1523 VICS Solenoid Circuit
P1524 Charge Air Cooler Bypass Solenoid Circuit
P1525 ABV Vacuum Solenoid Circuit
P1526 ABV Vent Solenoid Circuit
P1527 Bypass Air Solenoid (Accelerate Warmup) Circuit
P1528 Subsidiary Throttle Valve Solenoid Circuit
P1529 L/C Atmospheric Balance Air Control Valve Circuit
P1540 ABV System Fault
Manufacturer Specific Codes P1562 to P1570
P1562 Powertrain Control Module +B Voltage Low
P1566 TCM B+ Voltage Low
P1569 IMRC Circuit Low
P1570 IMRC Circuit High
Manufacturer Specific Codes P1600 to P11609
P1600 Loss Of KAM Power, Circuit Open
P1601 Powertrain Control Module Communication Line To TCM Error
P1602 Powertrain Control Module Communication Line To TCM Error
P1602 Immobilizer System Communication Error With Powertrain Control Module
P1603 Immobilizer System Fault
P1604 Immobilizer System Fault
P1605 Powertrain Control Module Keep Alive Memory Test Error
P1608 Powertrain Control Module (ECM CPU) DTC Test Fault
P1609 Powertrain Control Module (ECM CPU) Knock Sensor Circuit
Manufacturer Specific Codes P1621 to P1628
P1621 Immobilizer System Fault
P1622 Immobilizer System Fault
P1623 Immobilizer System Fault
P1624 Immobilizer System Fault
P1627 Powertrain Control Module (ECM/TCS) Line Communication Error
P1628 Powertrain Control Module (ECM/TCS) Any Line Communication Error
Manufacturer Specific Codes P1630 to P1649
P1630 Alternator Regulator #1 Control Circuit
P1631 Generator Output Voltage Signal (No Output)
P1632 Battery Voltage Monitor Circuit
P1633 Battery Overcharge Fault
P1634 Generator Terminal 'B' Circuit Open
P1645 Fuel Pump Resistor Switch Circuit
P1649 Fuel Injection Pump Module
Manufacturer Specific Codes P1650 to P1689
P1650 Power Steering Pressure Switch Out Of Range Fault
P1651 Power Steering Pressure Switch Circuit
P1652 Power Steering Pressure Switch Circuit
P1680 Metering Oil Pump Failure
P1682 Metering Oil Pump Failure
P1683 Metering Oil Pump Temperature Sensor Circuit
P1684 Metering Oil Pump Position Sensor Circuit
P1685 Metering Oil Pump Stepping Motor Cont. Circuit
P1686 Metering Oil Pump Stepping Motor Cont. Circuit
P1687 Metering Oil Pump Stepping Motor Cont. Circuit
P1688 Metering Oil Pump Stepping Motor Cont. Circuit
P1689 Oil Pressure Control Solenoid Circuit
Manufacturer Specific Codes P1690 to P1709
P1690 Wastegate Solenoid Circuit
P1691 Turbo Pressure Control Solenoid Circuit
P1692 Turbo Control Solenoid Circuit
P1693 Turbo Charge Control Circuit
P1694 Turbo Charge Relief Circuit
P1701 Transmission Range Sensor Reverse Engagement Error
P1702 Transmission Range Sensor Circuit Intermittent
P1703 Brake On/Off Switch Out Of Self Test Range
P1705 Transmission Range Sensor Out Of Self Test Range
P1706 High Vehicle Speed Observed In Park
P1708 Clutch Switch Circuit
P1709 Clutch Pedal Position Switch Circuit
Manufacturer Specific Codes P1710 to P1719
P1710 Transmission Control Module Solenoid/Internal Ground Circuit
P1711 Transmission Fluid Temperature Sensor Circuit Out Of Self Test Range
P1713 Transmission Fluid Temperature Sensor Circuit
P1714 Shift Solenoid '1' Mechanical Fault
P1715 Shift Solenoid '2' Mechanical Fault
P1716 Shift Solenoid '3' Mechanical Fault
P1717 Shift Solenoid '4' Mechanical Fault
P1718 Transmission Fluid Temperature Sensor Circuit
P1719 Engine Torque Signal
Manufacturer Specific Codes P1720 to P1739
P1720 Vehicle Speed Sensor '2' Signal Error
P1721 Gear 1 Incorrect Ratio
P1722 Gear 2 Incorrect Ratio
P1723 Gear 3 Incorrect Ratio
P1724 Gear 4 Incorrect Ratio
P1729 Transmission 4x4 Low Switch Error
P1735 First Gear Switch Circuit Failure
P1736 Second Gear Switch Circuit Failure
P1737 Lockup Solenoid
P1738 Shift Time Error
P1739 Slip Solenoid
Manufacturer Specific Codes P1740 to P1749
P1740 Torque Converter Clutch Solenoid Mechanical Fault
P1741 Torque Converter Clutch Control Electrical Fault
P1742 Torque Converter Clutch Solenoid Shorted
P1743 Torque Converter Clutch Failed On - TCIL Is On
P1744 Torque Converter Clutch Solenoid Mechanical Fault
P1745 Line Pressure Solenoid
P1746 Electronic Pressure Control Solenoid Circuit Open
P1747 Electronic Pressure Control Solenoid Circuit
P1748 Pressure Control Solenoid 'A'
P1749 Electronic Pressure Control Solenoid Circuit Low
Manufacturer Specific Codes P1751 to P1759
P1751 Transmission Shift Solenoid 'A' Mechanical Fault
P1752 Transmission Shift Solenoid 'A' Circuit Shorted
P1754 Transmission Coast Clutch Solenoid Electrical Fault
P1756 Transmission Shift Solenoid 'B' Mechanical Fault
P1757 Transmission Shift Solenoid 'B' Circuit Shorted
P1759 2-4 Brake Failsafe Valve Malfunction
Manufacturer Specific Codes P1761 to P1767
P1761 Transmission Shift Solenoid '3' Mechanical Fault
P1762 Transmission SS3/SS4/OD Band Fault
P1763 Low And Reverse Brake Pressure Switch Circuit
P1764 Low And Reverse Brake Failsafe Valve Malfunction
P1765 Transmission 3-2 Timing Solenoid Valve
P1767 Torque Converter Clutch Solenoid Circuit
Manufacturer Specific Codes P1770 to P1789
P1770 Clutch Solenoid Circuit
P1771 Throttle Position Sensor Circuit Open To Transmission Control Module
P1772 Throttle Position Sensor Circuit Shorted To Transmission Control Module
P1775 Torque Down Signal #1 Circuit
P1776 Toqure Down Signal #2 Circuit
P1777 Torque Down Response Signal Circuit
P1780 Transmission Control Switch Circuit
P1780 Overdrive Off Switch Not Cycled During The Self Test
P1781 Transmission 4x4 Low Switch Out Of Range Fault
P1783 Transmission Fluid Temperature High Input
P1788 Pressure Control Solenoid 'B' Circuit Open
P1789 Pressure Control Solenoid 'B' Circuit Shorted
Manufacturer Specific Codes P1790 to P1901
P1790 TP (Mechanical) Circuit
P1791 TP (Electric) Circuit
P1792 Barometer Pressure Circuit
P1793 Intake Air Volume Circuit
P1794 Powertrain Control Module Battery Direct Power Circuit
P1795 Idle Switch Circuit
P1796 Kick Down Switch Circuit
P1797 P/N Switch Open Or Short Circuit
P1798 Coolant Temperature Circuit
P1799 Hold Switch Circuit
P1900 Turbine Speed Sensor Circuit Intermittent
P1901 Torque Converter Clutch Circuit Intermittent
Old Dec 31, 2011 | 04:38 AM
CoRDiTe's Avatar
Not Mad
gsr.hatch
May 17, 2008 06:26 PM
MazdaMX3Freak
Mazda Tech
May 19, 2006 12:21 PM
clracergrl
The TRuck Forum
18
May 10, 2004 10:51 AM
phiray83
Aug 29, 2003 06:46 AM
