Codes??? Check Engine
Old May 16, 2008 | 12:43 PM
gsr.hatch's Avatar
Default Codes??? Check Engine
i Got A 95 Civic Hatchback Im Throwing 43 Fuel Supply System
what Dose That Mean??
i Got A B20z In It And An PO6 Ecu...lmk
K series}
D series} { B series}
scotty <3 roxy
...12_06_01...
William Scott Jr Preston Blake
...12_30_08... ...04_28_12...
Old May 16, 2008 | 12:51 PM
Todd's90's Avatar
0711, USMC
"defective or malfunctioning fuel supply system"
This is what the manual should say, still does not say much, maybe the fuel pump? did you check to see if it's coming on?
1990 GS-T
1990 GST
2004 BMW 325i
Old May 16, 2008 | 07:07 PM
lzylst's Avatar
First off your sohc fuel pump probably won't supply enough fuel for the b20.
Secondly the LS ecu won't have the correct fuel injector duty cycle for the b20.
To answer your question, check your fuel pump to see if its working.
Vance @ 863-604-2139 for any questions
Old May 16, 2008 | 11:59 PM
wb_map3's Avatar
when i threw that code in my ls it was my fuel filter but yea check your fuel pump b/c lzylst makes a good point.....
im grown but yea bitch i got batman bedsheets
Old May 17, 2008 | 07:53 AM
gsr.hatch's Avatar
K series}
scotty <3 roxy
...12_06_01...
Old May 17, 2008 | 05:54 PM
gsr.hatch's Avatar
Please Help!!!!!
I Tryed All That... Same Thing Is Goin On
K series}
scotty <3 roxy
...12_06_01...
Old May 17, 2008 | 06:26 PM
lzylst's Avatar
Main relay will cause the fuel pump to not work.
