help get this fc back up in running
Old Aug 26, 2010 | 02:08 PM
Deceiving Honda's Avatar
B anned
Default help get this fc back up in running
fucking shit is pissing me off hope some of you guys can help me out heres a video, and heres what ''i'' think its doing is its only getting fuel to one rotor, but how can this randomly be ? ive replaced the following parts with known good ones to see if these were the problem
n/a s5 maff
n326 trailing coil
440cc injectors ''primary's''
new ngk plugs
new main relay
ive also reved it up and the revs take forever to get to 5 grand than once it reaches 5 grand it acts like 2 step and back fires and if u give it a lot of gas it also back fires
much help would be great YouTube - rx7 running like shit for sale 4.000 $
i will give someone ether rotary parts of choice, or cash if they fix it heads up ford electronic guys
Old Aug 26, 2010 | 03:37 PM
jdmgt35r's Avatar
did you cheak your fuel pump,fuel filter, injectors, to see if its clogged?
Old Aug 26, 2010 | 04:03 PM
miataspeed's Avatar
have you check to make sure your secondaries are coming online, check to make sure you have power to all injectors and that your getting a signal to all four. what impedance inj are you running?
if you havent been in a small plane its worst, cause your eyes and brain say we are moving and your body says oh no we are not. eyes and brain go asshole we are moving, cant you see? body says fuck you we are not moving at all. so they fight and fight and eventualy your body says, you know what fuck you brain, see if you can stop this!! then you throw up.
Old Aug 26, 2010 | 04:27 PM
B anned
low independence on secondaries and high for primary's the secondaries have the 10k resister mod done and btw any one know how to check for injector pulse ? why would this be randomly happen thoe ?
Old Aug 26, 2010 | 04:34 PM
miataspeed's Avatar
you can use a dmm set for dc and back probe the inj plug, and run the car and you should see it switch from 12v to ground. or you can buy/borrow or rig up a inj test light adapter.
Old Aug 26, 2010 | 04:36 PM
miataspeed's Avatar
have you checked the comp on it?
Old Aug 26, 2010 | 04:47 PM
B anned
compression is fine car was running before it sat gonna test injectors tomorrow with ohm meter
Old Aug 27, 2010 | 06:06 AM
NI_racing's Avatar
Walboro's are known to fail every once in a while. I would definately check the pump and re wire the pump if it hasnt been done already simply to allieviate the possibility of it fucking up later if its not already. Also second the new fuel filter, its only a few bucks and its good to do.
Check the injectors with the multimeter like was suggested. If you are getting the proper reading and the cars still not running properly, i have a guy that cleans and repairs injectors (flow tests, o rings, the works) who charges 20 an injector. It might be a good idea to have them used injectors cleaned up a lil, and his shop is in Temple terrace so the turn around is usally a day or so max.
Other than that? well we'll have to go from there when we establish that the previous checks didnt resolve the issue.
Tampa Bay Rotary Owners Club Member # 4
PIT KREW
TEAM MEMBER
________________
Team Decep!
you never saw it coming
Old Aug 27, 2010 | 08:00 AM
miataspeed's Avatar
have you made any changes to the car or the setup when this started happening?
Old Aug 27, 2010 | 08:50 AM
NI_racing's Avatar
like that rare japanese chipped ecu?
PIT KREW
TEAM MEMBER
________________
Team Decep!
