help get this fc back up in running
no like what number is the ecu
if you havent been in a small plane its worst, cause your eyes and brain say we are moving and your body says oh no we are not. eyes and brain go asshole we are moving, cant you see? body says fuck you we are not moving at all. so they fight and fight and eventualy your body says, you know what fuck you brain, see if you can stop this!! then you throw up.
kk, doesnt the n374 have an issue with rear primary injector signals in a usdm car?
have you taken the injectors out to make sure theres no crud or anything blocking them or in the fuels lines?
could i have a clogged fuel line ? gonna try blowing compressed air threw it
gotcha, but yea it def sounds like a fuel or fuel supply issue. walbro's are junk, i've gone through multiple walbros on a few diff cars.
hook all the turbo stuff back up (ecu, maf ect...) reset the ecu and you should be good. have you pulled any codes?
last car that did what you describe it was the fuel pump. did all the same stuff you described and got so bad to where the car would only idle nothing else
reset and check the fuel pump and youll be ready to rock and roll.
TR "Old Skool EF" Member #48
99 Mitsu Eclipse GS-T DD
91 Honda CRX Si
91 Honda Civic Si
91 Honda CIVIC Si FOR SALE da front brakes. mint interior, 650 buks
91 Honda CRX Si
91 Honda Civic Si
already checked fuelpump and is fine could the fuel pressure regulator on the rail be bad ? lkq didn't have a good harness so im not changing out the harness going to swap out map sensor and fuel pump relay see if thts it i do have another fpr any way
