help get this fc back up in running
Old Aug 27, 2010 | 09:21 AM
miataspeed's Avatar
lol^ exactly
if you havent been in a small plane its worst, cause your eyes and brain say we are moving and your body says oh no we are not. eyes and brain go asshole we are moving, cant you see? body says fuck you we are not moving at all. so they fight and fight and eventualy your body says, you know what fuck you brain, see if you can stop this!! then you throw up.
Old Aug 27, 2010 | 11:48 AM
vortes's Avatar
Originally Posted by miataspeed
lol^ exactly
i think he hooked up another ecu and that didnt fix the problem
Old Aug 27, 2010 | 02:38 PM
Deceiving Honda's Avatar
B anned
theres no help here just negativity.... but any ways today took to jeff at maztech and did a compression check rotors have almost perfect compression did spark and coil test also fine. checked injectors all are fine and getting signals.. tomorrow im going to check the fuel pump but its not making any out of the ordinary noise ? checked the wiring on it today and is fine... any one give me a offer on this rx7 ? throw em up i wanna see what ''YOU'' think its worth
Old Aug 27, 2010 | 02:43 PM
B anned
have you made any changes to the car or the setup when this started happening?
and no it was running before it sat
Old Aug 27, 2010 | 02:51 PM
miataspeed's Avatar
what do you mean theres no help here? if your soo smart and knowledgeable then fix your own car
Old Aug 27, 2010 | 02:56 PM
B anned
^ exactly the negativity i was talking about.. if a ASE CERTIFIED rotary mechanic cant fix it than how can i ? or did you not read the post ?
Premature Walbro Failure - TurboBuick.Com
Old Aug 27, 2010 | 02:58 PM
  #17 (permalink)
B anned
any one have a 3rd gen fuel pump ?
Old Aug 27, 2010 | 06:26 PM
  #18 (permalink)
prican's Avatar
hey if you need a good rotary mech shared_pm me
R.A.P.S member number #0006
Rotaries
Against
Piston
Swaps
msn: prican8069
yahoo: ltorovelez
aim: ltorovelez
Old Aug 27, 2010 | 07:07 PM
  #19 (permalink)
B anned
heres 4 things i have in mind
omp is bad witch is putting it in limp mode
or fuel pump is bad
or pressure sensor is bad
or fuel pump relay is casing the pump to fluctuate ?
gonna check all three tomorrow, i would like some one to drive to my house so i could use there pressure sensor
Old Aug 28, 2010 | 06:33 AM
  #20 (permalink)
miataspeed's Avatar
what ecu code are you running in your car?
