rotary help needed
Old Sep 7, 2007 | 04:47 PM
  #21 (permalink)
Rotary7's Avatar
Get Down-Or-Stay Down
Originally Posted by budakinns
well i got the bolt that was connected to the front cover off. now i ran into another road block the other bolts wont move period. i soaked them in wd-40 and still broke one of my extensions. imma soak them some more before i try again but my question now is. if i used an inpact to remove the bolts would that be a good or bad idea?
Im guessing the shorter hose is bad?
I actually think i still have one laying here..
ANYWAYS...
Heres what you need to do to be safe.. the one to the front cover.. Bring that adaptor also.. Cause if I remember correctly,When I got material from them to make my own custom hoses,they had to match some fittings,but I got the anodized fittings.Material costed me like $150.
DO NOT USE an impact on that shit.
I cant believe you would think about it.Spin that steel bolt out of that aluminum to fast you can fuck some threads up.
Either you have cheap tools or you dont know what you are doing,or both..
I have a 2 foot breaker bar and a 24mm socket,if thats correct..
What area do you live?
Do you want to be tazed?
Old Sep 7, 2007 | 04:48 PM
  #22 (permalink)
Rotary7's Avatar
Buddha,Didnt I show you about Amazon,or you took me for my needs before?
If they are open Saturday its only half day,btu most of the time they can make shit while you wait.
Old Sep 7, 2007 | 08:14 PM
  #23 (permalink)
budakinns's Avatar
Big Black Trucking
yeah i didnt mess with it yet started to rain and took off for the night. yes they are poor tools and thats why it broke. imma see what i can do tomorrow and i talked to the guys at that shop you talked about and they said they will be open till noon i think. i know i am going to have to order and new short hose i kinda broke it. oh well its a pita but good learning
Trucking them states
Old Sep 7, 2007 | 10:32 PM
  #24 (permalink)
Rotary Buddha's Avatar
zero pistons
You showed me it back before they moved. When they were in the shady part of downtown. Yep they are open on Saturday only till noon.
Old Sep 7, 2007 | 10:40 PM
  #25 (permalink)
sharingan 19's Avatar
"Da Man"
The short hose is a major PITA. you have to find a thin wrench (some crescent wrenches will work) to hold the adapter fitting in place while you use another wrench to get the line off.
It works best if you can wedge the handle of the wrench holding the fitting against something solid (not the radiator) and then you can use a breaker bar or some other form of leverage extender on the other wrench.
And if you put it on the low setting, an impact wrench is great for breaking the bolts loose. NOT taking them out and NOT putting them back in.
"If losing you are yet no mistakes you have made, a different game you should play" - Yoda
Old Sep 11, 2007 | 04:12 PM
  #26 (permalink)
budakinns's Avatar
Big Black Trucking
ok guys just got done. the short hose was easy getting back on but the long one i spent an hour trying to get that shit to fit right. thanks to all that helped out with info and thanks to maztech for hooking me up with a short hose i broke mines taking it off the front cover and the dude there just gave me a leaky one for free so much thanks for that. ill post some pics up once i get my hands on one of our laptops. didnt get a pic of them installed was already too dark and already put every thing together.
Old Sep 11, 2007 | 09:02 PM
  #27 (permalink)
"Da Man"
Another 7 back in action!
