rotary help needed
Old Sep 5, 2007 | 03:44 PM
budakinns's Avatar
Big Black Trucking
ok sweet i just got done and i found the leak. like the one dude said its the oil cooler lines that is leaking. does anyone know if the lines differ from an s4 to an s5 or are they the same.
Trucking them states
Old Sep 5, 2007 | 06:52 PM
sharingan 19's Avatar
"Da Man"
S4 and S5 oil coolers as well as their lines are all interchangeable (it also makes no difference if their turbo or N/A)
You already have replacement lines or are you still lookin?
And you DO NOT want to try to ran an S4 engine w/ S5 harness or vice versa. Nothing but headaches await you.
"If losing you are yet no mistakes you have made, a different game you should play" - Yoda
Old Sep 6, 2007 | 05:25 AM
budakinns's Avatar
Big Black Trucking
looking right now for some good used ones. bout to call maztech and see if they got any
Old Sep 6, 2007 | 05:41 AM
Rotary7's Avatar
Get Down-Or-Stay Down
take the hose off....
go to amazon hose on 50TH in Tampa,Next to fisher buggies..
They will make you a hose for about 50.?If I can remember correctly..BUT You need to bring the hose cause they reuse the banjo fittings.. they might try to sell you steel braided but its not needed.
Fuck a used one.
Do you want to be tazed?
Old Sep 6, 2007 | 06:26 AM
budakinns's Avatar
Big Black Trucking
ok cool that shop is about 20 minutes away ill do that then. thanks for the heads up
Old Sep 6, 2007 | 09:19 AM
Rotary7's Avatar
take pics of it and let us know on the cost
they make these hoses all the time for scott or jeff,so they know what to do..
Old Sep 6, 2007 | 10:45 AM
  #17 (permalink)
budakinns's Avatar
Big Black Trucking
yeah im waiting on some friends it see if they have the 23mm and 21mm wrenches ill post some pics of the ugly engine bay tomorrow looks like ill be taking the lines off tonight or early tomorrow morning.
Old Sep 7, 2007 | 04:18 AM
  #18 (permalink)
Rotary Buddha's Avatar
zero pistons
Yeah like Tony said. Amazon Hose is great for that kind of stuff. They will have what you need.
Old Sep 7, 2007 | 07:43 AM
  #19 (permalink)
Rx7_guy's Avatar
As much as I like rotors I think you should sell it and get your self a Civic or Toyota. If you can't afford to pay the bills...you can't afford the Mazda. Hopefully, you get the cooler lines changed... Its a real bitch and messy. Specially the line on right when your facing the car...its a Pita. Don't forget new crush washers.
JDM FC
Old Sep 7, 2007 | 11:47 AM
  #20 (permalink)
budakinns's Avatar
Big Black Trucking
well i got the bolt that was connected to the front cover off. now i ran into another road block the other bolts wont move period. i soaked them in wd-40 and still broke one of my extensions. imma soak them some more before i try again but my question now is. if i used an inpact to remove the bolts would that be a good or bad idea?
