fd questions....help im a noob
Old Aug 29, 2006 | 07:47 AM
  #21 (permalink)
boostin13b's Avatar
Rotary Pirate
depending on what you want, LS1 is a good swap no matter what anyone says. I personally wouldn't do it just because I'm a true rotor head. No matter how many problems I have with them, I'm all rotary. I've had a ton of them and always will. I've seen a ton of LS1 RX7's and they run great, if you just like the body style of the FD, then that is a great swap. I have seen LS1 FD's car in action and it's impressive. It will be when you throw that much horsepower and torque in a car that light. Like he said it does not throw the weight off that much, and there are ways to make it 50/50.
LS1 swap isn't cheap either. Nomatter what you do with an FD, be prepared to spend money, whether it's making the 13b reliable, or going 20b, or LS1. I'll do a 20b in the near future most likely just because I want reliable 600+ rotary horsepower, yes you can do it with a 13b, but it's way less stressfull on a 20b than a 13b, and I drive my FD as much as possible.
Old Aug 29, 2006 | 10:03 AM
  #22 (permalink)
Rotary Buddha's Avatar
zero pistons
is this the same geoff i went drifting with like 2 years ago?
Old Aug 29, 2006 | 10:43 AM
  #23 (permalink)
pianoprodigy's Avatar
I took the turbo out...
Go to RX-7 Owners Club - powered by vBulletin and start reading...
Current: LS1-powered 88 Mazda Rx-7 : Forged : Heads/Cam : Traction???
On Hold: H/C LS1-powered FD - Doing it Once, Doing it Right, Eventually...
Daily Driver: 2000 Mercedes SLK230 - 2900 lbs : 190 hp : Upgraded Audio
Past: 420 rwhp '02 H/C EB Z06 - 230 rwhp S/C FC - 230k mile '90 Toyota
