Project Hi-Boost
I was going to get either Manley's or Carrilos for this build, but I wouldnt hesitate to put Eagles in it based off of what I have learned about them, and experiences with them...
Project WHIPLASH has begun!!!
InductionPerformance.com
NS Racing (813)842-5517
on stock rods, maybe.... Think about how an engine works, 4 strokes, intake, compression, combustion, and exhaust..
The intake stroke is the the only stroke where lateral load is place on the rod cap, and rod bolts. This is when the rod/piston is pulled down by the crankshaft, drawing in the uncombusted air/fuel mixture...
On the compression stroke, the crank rotates upwards, pushing up on the bearings and beam of the rods, which pushes up on the wrist pin and piston, pushing the piston upward to the top of the compression stroke... (TDC)
During the combustion/power stroke, all of the lateral load from combustion/horsepower/torque pushes down on the piston/wrist pin, which pushes down on the beam of the rod, and into the bearings and crank, until the completion of the stroke (BDC)...
And on the exhaust stroke, lateral force is again applied in an upward motion by the crankshaft, again placing the load on the rod beam, wrist pin, and piston, coming back to TDC expelling exhaust gasses and preparing the cylinder for the intake stroke imediately following....
In the grand scheme of things, the inertial loads really are not that much when compared to lateral loads, which as you can hopefully see are mostly placed on the beam of the rod, not the cap and bolts...
Hope that helps
Hope that helps
It's not the horsepower that affects rod bolts, its the inertial loads of high rpm's... There's actually a thread on H-T about that now...
link to thread plz?
www.mcgtile.com - Professional Marble and Tile Installation
Racing Integration
Proven Power
Racing Integration
Proven Power
JumpManPm me for any needs for a Honda/Acura/Evo. From tune ups to motor builds
