Justin's 1997 nissan 240sx 2jz-gte swap :) Hybrid motorsports
Old Dec 13, 2011 | 05:08 AM
BABILLARACING's Avatar
ok cool ,i have the stock fuel tank cover already
My shit still slow
618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
stock block ,more power coming soon ,stay tuned
Tuned by Alpha @ Induction Performance
Old Dec 13, 2011 | 06:51 AM
91180sr's Avatar
yes! ITS TIME.
04 z33 Track- N/A
91 180sx-
Old Dec 13, 2011 | 04:10 PM
bikeimports's Avatar
^ Indeed it is
Started working on some misc stuff:
Tial 44mm mvr:
Went and got a j30 as a temporary diff, opened it up cleaned it out, resealed it and installed it:
Old Dec 17, 2011 | 04:37 PM
Started prepping the engine : Mounted the manifold /turbine housing and wastegate, also modified the coolant inlet pipe:
Old Dec 17, 2011 | 04:59 PM
Tapped neck:Garrett GT3582R chra: PI 3800 stall converter:
Old Dec 18, 2011 | 07:40 PM
Well mated engine & transmission and put it in to double check clearances:....everything looks good with the new mounts.
Gonna need to modify the intake manifold:
Had to remove this much off the water union on the back off the head, basically cut right above the second bead on the tube:
Old Dec 19, 2011 | 11:55 PM
  #17 (permalink)
Removed the sub frame & to get to the fuel tank for clean and remove the stock lines. And received my driveshaft today
Old Dec 20, 2011 | 04:30 AM
  #18 (permalink)
Justing who made you the drive shaft ? can you pm a price?
My shit still slow
Old Dec 22, 2011 | 01:00 AM
  #19 (permalink)
Petitt's Avatar
The Riot Society
What is this car being built for? Looking good so far.
Old Dec 22, 2011 | 07:38 AM
  #20 (permalink)
Street / Strip... Thanks
