b18c tech
Old Jul 8, 2003 | 08:42 AM
99B16Si's Avatar
chris, that pretty much the same setup anthony has. he has no problems with detonation. just make sure u get some good cams if ur getting the valvetrain.
and integra nemesis,
type r bearings and gsr bearings are different
Old Jul 8, 2003 | 09:52 AM
TEP-ITR-REX's Avatar
Motor combo sounds sick, I'm eager to see what you put down to the wheels? I have a b17 .25over CTR pistons, ITR Head complete, ITR IN. MAN, ITR TB, and some other goodies, but im expecting, 11.4 compresion in the b17, I also have some ITR Rods but i dont think im gonna use them in the B17, Anyone have any ideas....Any TIPS>>>Thanks
I drive a HONDA so what!! My GF is BANGIN must be the MOTOR...
Old Jul 8, 2003 | 07:09 PM
gotvtec20's Avatar
Import Tuner
Keith, when did I ever say I had an EG. If Im not mistaken, your the one with a logo of a rx7 with 92cxhatch. LOL. Just bustin your ballz. Anywayz, yea guys I cant wait to see what I put down either. I just dont want too much compression and when I spoke to someone today they stated with CTR pistons with an SI head and GSR block, I may have to retard the ignition timing. Now I have never heard of such a thing. O yea i have CTR intake cam and ITR exhaust cam going in the head with a skunk valvetrain. ITR Intake manifold, 65 mm throttle body, and ill have to add a fuel pressure regulator along with the VAFC I already have (which hasnt helped for crap!!). Thanks for all the replies. I learn as I go.
03' BMW 330XI
Old Jul 8, 2003 | 09:22 PM
_Charles_'s Avatar
formerly 'RiceRocket'
Here are the "differences" that I know about...
B18c5 (vs....other B series...)
better oil pump
lighter crank?
lighter and stronger rods
pistons are moly coated
Bearing are different (probably either better material or closer specs)
Head is hand P&P
different cams
better springs and retainers
lost motion assembly only has 1 hole instead of 2 (don't know why)
better throttlebody
better intake manifold
Tranny has helicoil LSD
stronger clutch/pp assembly
I think that does it....of course I just came off of a 18 hour shift @ work...so I might have missed something
My Blog: www.HotRodCaddy.com
Old Jul 8, 2003 | 09:25 PM
_Charles_'s Avatar
Default Re: b18c tech
Originally posted by gotvtec20
Im just really concerned if the ITR rods are better in any way than the gsr rods. They both say P72 but the ITR has an "R" stamped on them.
hmmmm.never looked close @ ITR rods, but since they have a different material make-up, why wouldn't they be stamped P73? (I honestly have no clue....and really need some sleep)
Old Jul 9, 2003 | 07:29 AM
F4A22's Avatar
Old School
i also think they valves coated with a better material than other hondas
Old Jul 9, 2003 | 11:55 AM
  #18 (permalink)
gotvtec20's Avatar
Import Tuner
Well F#*k you then.
03' BMW 330XI
Old Jul 9, 2003 | 09:21 PM
  #20 (permalink)
gotvtec20's Avatar
Import Tuner
Anywayz, before this conversation was interrupted, I am going to stick with the JDM ITR pistons. they are 11.1 compression ratio with my head. with an 11.5 compression ratio I may have a few problems with fuel and ignition timing from what I am told by some of the tuners in tampa. Other than that, still determining where I can get a skunk manifold cheap.
03' BMW 330XI
