OK-trying this again...with a pic...PLease help
Old Mar 6, 2003 | 05:53 AM
  #21 (permalink)
KJ's Avatar
KJ
bored at work
Check the IACV and the FITV.
Probably one od those are the culprit.
Old Mar 10, 2003 | 06:22 AM
  #22 (permalink)
IGUTABONA's Avatar
i just had the same problem.{5000 rpms on the tach,same hose,different motor-but i will tell you where mine went in}there should be a valve all the way to the left of the injectors{if you are looking at the motor from the front.}it should be sticking straight up-so if you were looking at it you would see: {o}
Old Mar 10, 2003 | 10:59 AM
  #23 (permalink)
95civex's Avatar
Sorta Kinda O.G.
ok..ill check on that...thanks
