Skunk2 Intake vs. Stock
Talking to me? Eriks racing is an all motor coupe!
BTW, i have seen dyno charts of gsr Intake manifolds holding there own against Skunk's when FI!!
eric
eric
i am quite aware of the erick's setup.
FI doesnt at all represent flow numbers for NA applications. forced air will always flow relatively well in most applications.
as for NA, air velocity reigns supreme for creating power... bigger is not always better. considering the design of the GSR manifold compared to a single runner application, it's obvious as to why the single runner design will usually perform better by design.
the runners being short length in comparison to the long tubes on the GSR manifold are superior for top end performance. the GSR type is sufficient for most street applications as the short and long tubes combined provide for 2 different motor attitudes. but the application of the tube convergence and butterfly valves to control and divert airflow in the manifold will cause intake turbulence and resistance to flow that is only excacerbated in an NA configuration as the air isnt being forced thru the system... it's being pulled in at atmosphereic pressure.
1997 Prelude, H23A1 VTEC
Items for sale:
H22/23 block and all internal parts
4 5th gen Prelude wheels, 16x6.5, 5x114.3mm bolt pattern
More stuff for sale:
https://www.tamparacing.com/forums/showthread.php?s=&postid=472993#post472993
Items for sale:
