easy hp for my eg civic?
Old Sep 20, 2011 | 08:00 PM
jbundrum's Avatar
Default easy hp for my eg civic?
im sorry if this has been covered before but i couldnt find anything on it. i have a mostly stock z6 and i want know that there are stock emission control components that rob horsepower, my question is besides header/exhaust and cold air intake if there are any factory deletes or anything like that i can do for a couple extra hp here and there
Old Sep 22, 2011 | 02:29 PM
jdmricardo's Avatar
[JdmEghastck813]
cams vtec killer and tuned and itb lol
[ RICARDO_DYNO BOOST]
Old Sep 22, 2011 | 08:30 PM
jbundrum's Avatar
im looking to get a little more hp from my stock motor for now but it has 200,000+ miles on it never rebuilt. it runs strong still but ill be building another motor on the side for itbs or turbo. im planning on doing a cold air, full exhaust, and msd but just looking to see if i can find some hidden hp by doing some factory deletes or something simple for now.
Old Sep 23, 2011 | 07:58 PM
Secondz's Avatar
Built Not Bought
Old Sep 23, 2011 | 08:08 PM
teamjdm239's Avatar
6speed rhd integra!
actually yes, there is a pretty simple trick you can do.. you wire in a 12v to a 12v power on ignition (when ignition is on, power is on.) you run it to the back seat, you take off the fuel pump cover, hook up a ground , and run the wire into the tank, then make sure you do the same with the 12v wire, (if i were you the safest way is to run it through the grommet that the other wires are running through on the lid.) what this will do is send double the voltage to the fuel pump causing you to gain another 5-6 hp.
not really. but in all seriousness. there is no deletes that will make you gain hp. if i were you i would just swap out that motor. especially with 200,000 miles.
K*Squad
Uk spec 99 rhd dc2 integra
MugenPower
Old Sep 27, 2011 | 11:17 AM
Paulino's Avatar
Not harsh, just truthful
Sounds like an "LS" B18B1 motor swap will be just what the doctor ordered for ya. It's easily obtainable, cheap to look after/modify, etc....look into it
Old Sep 29, 2011 | 01:17 PM
JUST JON's Avatar
take the intake of jus run straight throttlebody youll gain a lil fromthat no filter.scunk 2 intake mani blox throttle body 310 injectors and a tune allfor under 500dollars
Old Sep 29, 2011 | 01:46 PM
lokoking69's Avatar
waiste 500ish on single cam on last days or put 500 toward b swap ....emm thats a hard one^
also i jus read the parts u posted HELL NO jus the manifold and the throttlebody gonna b around 600ish any good tune gonna b 200-400 and thats not even buyn injector u mentioned
mustwonder
For Sale/WTB Honda & Acura
16
Aug 27, 2011 06:08 PM
crankshaft3rd
Jul 17, 2011 12:34 PM
bmwdrifter
7
Jul 12, 2007 02:46 PM
vetkilr
Jul 19, 2003 04:32 AM
dusty
War Stories
5
Dec 10, 2001 01:39 PM
