alignment still shaking!!!!
Old Aug 30, 2011 | 04:03 PM
88_Hatchy's Avatar
I'm cooler than you
9222 N. Florida Ave. 9-6
Honda-Tech > TampaRacing
TR "Old Skool EF" Member #666
Old Sep 2, 2011 | 10:13 PM
How does the length of both the new and the old axle stubs compare?
How does the total length of both the new and old axles compare?
If lengths are the same in both cases, do a test fit of the old axle and see if it goes in ok.
If it doesn't go in,...same as the new axle doesn't go in, pull it out, measure how far the
axle should go in and look for some kind of obstruction.-Bob
Originally Posted by mr.hatch
i have energy tie rod bushing that can't be more than 2 years old. my lca have zero play side to side. i actually think i found the problem and i think it may be that my axle on the driver side isn't going all the way into the tranny, i've messed with it for 2 days and i just went and got a "BRAND NEW" not re-man. axle and it is doing the same thing where it's just not going in all the way, i used as much elbow grease i had to get it but i am to the point where i want to just get rid of it so unless someone gives me a for sure way to get that bitch in you'll see both my crx and my hatch up with everything i got for trade
Ferrit1992
Sep 27, 2007 08:05 AM
hondaaccord
Jun 8, 2005 12:55 PM
zenki_s14
Nissan/Infiniti Tech
14
May 23, 2004 09:45 PM
Penis
Nov 27, 2002 04:31 PM
