shaking
Old Jun 6, 2005 | 01:59 PM
hondaaccord's Avatar
Default shaking
i have h22a motor in my 94 accord.when i drive 45 or less the car is fine no shaking at all.then after about 45 to 70 the whole car shakes crazy after 70 its normal again i dont get it.i had the wheels balanced and alligned.i have 17'' rims with stock shocks and springs.but there is a rim thats bend on my car i mean its a little bit u cant even notice that much.i had them do rotation i tried everything when i tell car shops around tampa whats my problem they just send me to another shop and it keeps going i dont get it.so if anyone possible know what could be wrong with my car just post. and if u guys know anyone that could fix this problem that'll be great.thanx
Old Jun 7, 2005 | 06:51 AM
DOHC16CRX's Avatar
CARPET GUY
have you checked the wheel bearings? also check the tie rods..if you have any play i would replace it.jack the car up and grab the tire.if it moves up and down its the wheel bearing..if its side to side then its the tie rod.you also might want to check the upper control arm bushings cause they go bad alot..
EATING FORDS-SHITTING CHEVY'S
MOBIL 1 LUBE
11210 Causeway Blvd. Brandon 33511
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
At the Mobil 1 Lube in brandon we service all your automotive needs.Specialize in Honda/Acura. B series swaps etc. No job to big or small.We are located right in front of Walmart. Ask for Nate.
Old Jun 7, 2005 | 08:29 AM
do u know who could do that for me down here in tampa.actually it does move side to sideso its probably the tie rod.who does that kind of work down here?
Old Jun 7, 2005 | 08:37 AM
DOHC16CRX's Avatar
CARPET GUY
ANY where does it that does alignment..if i were you i would go and buy a tie rod and bring it in to them..they try to kill you on the price of the part and they are like 25-30 any where that sells auto parts.call MR TIRE at 813-234-0194 and ask for andy .they are on hillsborough and 40 some thing street..
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
Old Jun 7, 2005 | 09:25 AM
thanks a lot man i appreciate that
Old Jun 8, 2005 | 07:56 AM
juiced2ndgenteg's Avatar
you have bent rims, that is all.
Old Jun 8, 2005 | 08:13 AM
tranceologist's Avatar
TR Shop Mod
try another set of rims w/ tires, i recommend tires that arent balled, and eliminate that option. maybe a motor mount if not the tires. just tryin to help bro
Old Jun 8, 2005 | 09:02 AM
lowoctane's Avatar
Professional Dumbass
when i worped my tires it made my car shake like crazy, off balance?
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old Jun 8, 2005 | 12:23 PM
DOHC16CRX's Avatar
CARPET GUY
the guy said his tires move from side to side and you all are still saying its a tire.LMAO..a rim might be some of the problem but if a tie rod is bad it will never be correct...just call andy and fix it right the first time..
MOBIL 1 LUBE
813-661-7284 shop
813-476-8015 cell
813-347-0291 cell
Head Mechanic
