shaking
Originally Posted by DOHC16CRX
the guy said his tires move from side to side and you all are still saying its a tire.LMAO..a rim might be some of the problem but if a tie rod is bad it will never be correct...just call andy and fix it right the first time..
Heres your list to check.
RIMS ! Tires ! THAT IS ALL
Tie rods will not cause vibration just bad steering, sloppy steering.
Wheel bearing will make a noise if its bad. You WONT miss that one.
The Back and forth movement test is a crock. I did that to customers all day OH look mam your tie rods are bad look at the play i get !
Check all your joints and try a different set of tires and wheels.
Motor Mount wont cause this at different speeds. It would vibrate constantly and change at RPM.
Since you have a speed diference in effect its your rotating assymbles ie WHEELS AND TIRES ! have you had JUST the rims balance ? prolly not I bet that RIm is more bent than you think !
