Shifting/tranny problem
Old Jun 17, 2011 | 05:10 PM
thatkoolkidSD's Avatar
Default Shifting/tranny problem
The tranny's all good but the shift rod is like really loose?
so it's hard to get into gears, what do i need?
new shift linkage all together or?
Old Jun 17, 2011 | 07:07 PM
Gheremy Harrison's Avatar
BB2 El Rey
Shift bushings
H22 ALL DAY EVERYDAY!!
Old Jun 17, 2011 | 07:48 PM
bettaberettaboy's Avatar
That Fat Guy
Yeah try those before anything should solve your issue, theyre are relatively cheap and easy to find
Old Jun 17, 2011 | 08:01 PM
i actually did, but it didn't help :o
Old Jun 18, 2011 | 06:36 AM
Secondz's Avatar
Built Not Bought
just go buy a whole new linkage with good bushings and it might be loose if you dont have a bitch pin and someone half assed your car or if you did it yourself, you may have a nut and bolt where the bitch pin should be
Old Jun 18, 2011 | 12:16 PM
bisscrac's Avatar
what kinda car is it?
私の狂気にそこに方法があります
https://www.facebook.com/groups/534257953308376/
Old Jun 19, 2011 | 09:51 AM
bitch pin?
Old Jun 19, 2011 | 12:32 PM
chi town brat's Avatar
! Ne shab'rud'ni !
bitch pin - the pin that you can't get out and your arms are wasted by the time you do
if your shift linkage was modified to be put in your car sounds like something is wrong. i have this with my CRX. even after the fix, I'm still not happy with the play in the shifter espc down the drag strip.
Old Jun 19, 2011 | 04:48 PM
eg 4 door, and um alright. i think i know which pin. i'll just try replacing the whole shift linkage, i can hit every gear just fine but my dad would like to be able to drive the car as well.
Old Jun 19, 2011 | 07:01 PM
MikeyL513's Avatar
BOOSTIN
^when you go to replace the shift linkage, you will figure out what the "bitch pin" is lol
airmanhoward
Oct 27, 2010 08:02 PM
Silk_240
Nissan/Infiniti Tech
37
Jan 20, 2009 03:48 AM
seventhgear
Apr 22, 2008 08:56 PM
ThE iNfAmOuS p MoNeY
Aug 3, 2006 06:53 PM
