Tranny problem ??????
There is a 17mm bolt right above the passenger side axle. Take it out, get a tranny fluid tube from walmart (under 7 bucks) fill it up with honda mtf or 10w30u motor oil until it starts dripping out of that hole. That means its full. Put the bolt back in and test it. If it doesn't fix it. Maybe a internal tyranny problem or clutch issue
H22 ALL DAY EVERYDAY!!
^^will be doing asap and i will let you know how it goes. you've been repped man thanks ^^
any other help is appreciated fellas .
Official TR "EK" Krew member #57
